4in CAI tube options
Old Aug 8, 2011 | 06:35 PM
BlackGMC's Avatar
Resident Retard
Default 4in CAI tube options
I am just wondering if any of yall run a full 4in intake tube? I have been wanting to redo mine since i added the TBSS intake. The way the TB mounts it actually points upwards some which causes my damn Airaid intake tube to hit the hood. I have been thinking about replacing the whole damn thing with a piece of 4in mandrel bent tube... Just wondering who all has done it and pics would be great.
Old Aug 8, 2011 | 06:42 PM
BlackGMC's Avatar
Resident Retard
Another to add to this. If i do switch it out for a 4in pipe i am concerned with the possible heatsoak that occur from the huge chuck of metal. I could make the tube out of fiberglass but that is alot of work
Old Aug 8, 2011 | 06:52 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Ive got a 4" aluminum tube from intakehoses.com if you want it.
Old Aug 8, 2011 | 06:58 PM
andrew383's Avatar
traveling mod
4" 90 and 2' section of 4" is about $100 from siliconeintakes dot com..
Stock maf will be going by by before to long also..
Mine hit the upper hose but im working on a fix for that also
Old Aug 8, 2011 | 06:59 PM
BlackGMC's Avatar
Resident Retard
I am looking at a 1 piece L pipe from dynomax. So all i have is 1 straight coupler at each end. Also i am kinda tossing aroumd the idea of buying the TSP 100mm MAF since i like running the MAF, but i will be adding a screen to it to straighten out the airflow much like the stocker
Old Aug 8, 2011 | 07:02 PM
BlackGMC's Avatar
Resident Retard
Nice. Yep i am gonna have to mod the waterpump too. I have allready got an idea for that one
Old Aug 8, 2011 | 07:09 PM
low2001gmc's Avatar
Mine used to barely touch also but i got a cowl hood now
Old Aug 8, 2011 | 07:18 PM
1slow01Z71's Avatar
Or you could just go to a new style pump where the exit goes straight out.
Old Aug 8, 2011 | 07:24 PM
andrew383's Avatar
traveling mod
Cody post a pic of your tube
Old Aug 8, 2011 | 07:25 PM
BlackGMC's Avatar
Resident Retard
I think those are kinda spendy, no?
