42 # Injectors
Old Dec 19, 2010 | 09:16 AM
JDC's Avatar
JDC
Default 42 # Injectors
How much HP will the 42# 8.1 injectors support ? I read in the forsale adds someone said only 450. Is this right ?
Old Dec 19, 2010 | 11:44 AM
fredkj3's Avatar
this is not a scientific number but probably somewhere around 450-500... because you dont want to go past about 80% of the duty cycle... but also fuel pressure can increase or decrease the injector flow...
heres a neat little calculator
http://www.witchhunter.com/injectorcalc1.php4
Old Dec 19, 2010 | 12:00 PM
JDC's Avatar
JDC
Thats a good link. But how will I know what my HP will be on my engine untill its actually dyno'ed
Old Dec 20, 2010 | 06:50 AM
03 BLACKOUTSSS's Avatar
you can speculate, thats it. Take your best guess and try to match the injector. Then dyno it and look at inj. duty cycle to see how close you are.
What are you building that you are worried that 42lb inj. might be insufficient?
Old Dec 20, 2010 | 02:19 PM
JDC's Avatar
JDC
Originally Posted by 03 blackoutsss
you can speculate, thats it. Take your best guess and try to match the injector. Then dyno it and look at inj. Duty cycle to see how close you are.
What are you building that you are worried that 42lb inj. Might be insufficient?
a 408 !
Old Dec 20, 2010 | 03:18 PM
Atomic's Avatar
I have a gauge for that
save yourself from doing it twice and go with 60s
Old Dec 21, 2010 | 06:16 AM
JDC's Avatar
JDC
Does someone make the 60# injectors that are plug & play? I dont like cutting up my harness if I dont have to.
Old Dec 21, 2010 | 08:06 AM
Atomic's Avatar
I dont think so but you can buy adapters if you don't want to splice
Old Dec 21, 2010 | 03:55 PM
fredkj3's Avatar
yea id def go bigger.. you dont wanna be too close and risk leaning out on the top
Old Dec 23, 2010 | 06:23 AM
JDC's Avatar
JDC
Thks for the info guys. And I found some plug and play 62# Delphi multec II's on fiveomotorsports web site. They have 42# up to 72# .
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
