408 build
Old Sep 30, 2005 | 01:59 PM
mwalls54's Avatar
Need More N2O Mod
Sounds you are on the right track. thats basically what I have. right now i am running stock 317 heads.
Old Sep 30, 2005 | 02:35 PM
zippy's Avatar
and damn is it torquey. drives great.
Old Sep 30, 2005 | 04:06 PM
black4x4's Avatar
are the times in your sig with that setup and if so what did you wiegh when you ran those numbers and how much were you spraying.
Old Sep 30, 2005 | 04:28 PM
mwalls54's Avatar
Need More N2O Mod
Those times were with the 6.0, the very mild 408 is running in the mid 13s n/a weighing around 5500 give or take a few hundred pounds.
Old Oct 1, 2005 | 12:16 AM
zippy's Avatar
if you've ever driven a 6.0L with a radix that's well dialed in, that's about how his drives. outstanding power at all rpm.
Old Oct 1, 2005 | 04:02 PM
black4x4's Avatar
Is his cam bigger then the biggest one i listed? and what will i need for injectors
Old Oct 1, 2005 | 08:01 PM
zippy's Avatar
the cam he has that is going to go in there is bigger. for break in he put the same cam in that he had in the 6.0L which is much milder. it idles like a stock truck even if you set the idle to 500. there is no lope. the new cam should allow for power beyond 6000rpm.
OHsixLS3
Sep 25, 2015 11:20 AM
2500ZL1
Sep 12, 2015 03:50 PM
11MPG
Sep 10, 2015 08:34 PM
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
