4.8 swap to 6.2, some help!
Old Nov 24, 2015 | 01:29 PM
walidmurad's Avatar
Originally Posted by Wolftrk99
If it is rear end bearing noise plan to replace all the bearings anyway and you shoukd be fine
I will replace all the parts but I don not know the name for the part's to order it. I just know about "spider gears" and I dont know what he do to the diff.
Old Nov 24, 2015 | 02:07 PM
mikeyjm1's Avatar
Just order a complete bearing set with the ring and pinion set and Truetrac. And have a reputable shop do the whole job. I ordered everything at 4WheelParts. I'm lucky since I have a location locally but their good to deal with online too.
Old Nov 24, 2015 | 03:44 PM
walidmurad's Avatar
Can you talk with my in my number to get more info ? My number is 1(786)719-9390. Thanks.
Old Nov 24, 2015 | 06:27 PM
mikeyjm1's Avatar
I'm in Kosovo currently. what do you want to know?
Old Nov 24, 2015 | 07:16 PM
Wolftrk99's Avatar
Ring and pinion are the gears themselves, the spider gears are inside the differential carrier and turn the axles with the ring gear, the carrier beatings on on the sides of the carrier under the caps, axle bearings are at end of the axle tubes pinion bearings inner and out are on pinion gear shaft, which the pinion yoke attaches to....which attaches to the drive shaft through the u joint....
Old Nov 25, 2015 | 01:55 AM
mikeyjm1's Avatar
You wont need worry about spider gears if you're getting a TrueTrac. That's an entire new differential so it'll replace all of that. the ring gear just gets bolted to it and in it goes.
Old Nov 25, 2015 | 07:04 AM
Tig's Avatar
Tig
You'll love the trutrac, best LS rear for the money. I have had them in 3 other vehicles as well as my 07 Tahoe.
You'll need a master rebuild kit for a GM 10 bolt, make sure you find one specific to your year. I think they vary in years so you if you buy one not specific you may be missing some parts.
I'd also find a 4x4 shop to do the work.
Good luck and good luck with the swap to, I'm looking to do the same with my Tahoe, 5.3 to 6.0 bored out to a 6.2
Old Nov 25, 2015 | 08:19 AM
mikeyjm1's Avatar
Miami right? I'm pretty sure there is a 4Wheelparts there. Unless you know someone you really trust. You may pay more but its been my expereience, you'll get good sevice and quality work.
Old Nov 25, 2015 | 08:25 AM
Tig's Avatar
Tig
I agree with Mike, that is why I said find a 4x4 shop.
Find some shady shop, get shady work.
You definitely get what you pay for and you don't want to mess with your rear end. Unless you have experience working on them.
Old Nov 25, 2015 | 10:47 AM
walidmurad's Avatar
thanks for explanation.
