4.8 build
Old Apr 13, 2007 | 06:28 PM
53bowtie's Avatar
Default 4.8 build
alright so i got my iron block 4.8 and my 5.3 crank to bore to 5.7 and i am tryin to get all my parts together....i am goin with forged internals and 317 heads but thats as far as i have got.....what is a good cam/spring/lifter set for this or could i use the stock lifters? also turbo, sc, or n2o? i am thinking turbo or could i maybe run both fi and n2o since it would be an iron block ls1? any other info or suggestions would be much appreciated!! thanks!!
Old Apr 13, 2007 | 06:52 PM
nightrunner's Avatar
Mr. Obvious
you can use the stock lifters
the cam will depend on if you go SC, turbo, or NA/nitrous
you are going to have to decide on sc, turbo, nitorus, naturally aspirated before you build your engine, unless you want to change some things later $$$$
there is tons of info on here, so read up
Old Apr 13, 2007 | 07:23 PM
53bowtie's Avatar
thanks i will do that.....i was hoppin to find someone who had done somethin similar to see what they were runnin.....i will search around though.....
Old Apr 13, 2007 | 07:26 PM
Mr. Obvious
curt D did a forged iron block 5.7 ( from a 5.3) with a front mount turbo and made over 600rwhp on the dyno at 15lbs. and over 500rwhp at 11lbs.
Old Apr 13, 2007 | 07:27 PM
53bowtie's Avatar
that would be what i am looking for....i figured maybe turbo since they are easily upgradable i just dont know if i want to do a remote mounted or under the hood....i guess they both have their pros and cons
Old Apr 13, 2007 | 07:29 PM
Mr. Obvious
yep
check out the forced inductions section and read the stickys, lots of good info in there
i prefer a roots/twin screw SC myself but to each his own
Old Apr 13, 2007 | 07:36 PM
53bowtie's Avatar
if i dont do some kind of fi how big of a cam can i put in it and is still be streetable?
Old Apr 13, 2007 | 07:40 PM
Mr. Obvious
that all depends on your idea of streetable but id say somewhere around a low-mid 230s duration max, and i wouldnt go that big
the tune also affects the driveability alot
maybe someone else with some experience will chime in, for i have none when dealing with specing out cams and what not
Old Apr 13, 2007 | 07:51 PM
53bowtie's Avatar
this will be my first engine build so i def. dont have any.....the only thing i have put a cam and springs in is my 22R toyota 4 banger....a little different than this....
luis_bullz
Sep 8, 2015 03:08 AM
Tigger Welder
Sep 2, 2015 08:17 AM
fastjweb
Aug 15, 2015 10:47 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Cowboy17
Jul 9, 2015 08:22 PM
