4.8 build
alright so i got my iron block 4.8 and my 5.3 crank to bore to 5.7 and i am tryin to get all my parts together....i am goin with forged internals and 317 heads but thats as far as i have got.....what is a good cam/spring/lifter set for this or could i use the stock lifters? also turbo, sc, or n2o? i am thinking turbo or could i maybe run both fi and n2o since it would be an iron block ls1? any other info or suggestions would be much appreciated!! thanks!!
you can use the stock lifters
the cam will depend on if you go SC, turbo, or NA/nitrous
you are going to have to decide on sc, turbo, nitorus, naturally aspirated before you build your engine, unless you want to change some things later $$$$
there is tons of info on here, so read up
that would be what i am looking for....i figured maybe turbo since they are easily upgradable i just dont know if i want to do a remote mounted or under the hood....i guess they both have their pros and cons
that all depends on your idea of streetable but id say somewhere around a low-mid 230s duration max, and i wouldnt go that big
the tune also affects the driveability alot
maybe someone else with some experience will chime in, for i have none when dealing with specing out cams and what not
this will be my first engine build so i def. dont have any.....the only thing i have put a cam and springs in is my 22R toyota 4 banger....a little different than this....
