4.8 to 5.7??
Old Apr 9, 2007 | 11:16 PM
53bowtie's Avatar
Default 4.8 to 5.7??
i am thinking of replacing my 5.3 in my 02 reg cab with a built 4.8(since they are cheaper). i have been told i can turn the 4.8 into basically a 5.7 iron block ls1. is this true?and what do i have to do to a 4.8 to make this happen....cam, head, and intake set up for this would be much appreciated as well....thanks.
Old Apr 9, 2007 | 11:26 PM
kbracing96's Avatar
You can't do that with the 4.8, it has a shorter stroke and longer rods. 5.3 and 4.8 share the same block, but the 5.3 has a longer stock crank then a 4.8. The 5.3 and 5.7 share the same crank and rods, so all you have to do is take a 4.8/5.3 block and have it bored out to the 5.7 bore and use a 5.3 crank and rods with 5.7 pistons and you will have an Iron block 5.7. Heads from any of the 3 motors will work, although the combustion chamber on the 5.7 are larger.
Old Apr 9, 2007 | 11:37 PM
53bowtie's Avatar
i want to eventually run some form of FI to it in the future so i would need lower cc chamber heads right? i was thinking of some 6.0L heads to do this and the 5.7 pistons will be flat top already so that will help....would you port the heads or just run them stock? thanks.
Old Apr 9, 2007 | 11:39 PM
RandomHero's Avatar
Wow a 5.3L to a 4.8L swap. That has to be the dumbest idea ever
Old Apr 9, 2007 | 11:42 PM
kbracing96's Avatar
That's actually the plan I have for my next motor, Iron 5.7 with 317 6L heads. SDPC had a pretty nice budget forged piston kit for the LS1's . I'm going to leave them stock. Parish went a long way with his 408 on unported 317 heads. You just run a little more boost
Old Apr 9, 2007 | 11:46 PM
kbracing96's Avatar
You were a newbie once too
Old Apr 9, 2007 | 11:47 PM
RandomHero's Avatar
Yes, but I don't think I've ever wnated to step down a motor size.
Old Apr 9, 2007 | 11:56 PM
53bowtie's Avatar
goin from a 5.3 to a 5.7 isnt exactly steppin down in motor size......i like the piston set a sdpc and the 317 heads, how about a cam for that set up....about what size were you thinkin on yours?
Old Apr 9, 2007 | 11:57 PM
RoosterMcCandles's Avatar
He wants to go from a 5.3 to a 4.8. He was just wondering if he could make the 4.8 a 5.7...
Old Apr 10, 2007 | 12:05 AM
RandomHero's Avatar
what do i have to do to a 4.8 to make this happen....cam, head, and intake set up...
This statement threw me off then.
