4.8 and 5.3 piston
#32
If you got it cheap enough punch that bitch out to an LS1. For your desired power level, forged is not necessary.
Sonic, hot tank, line bore, bore, polish crank you're probably looking at about $800.
Get yourself a set of LS1 pistons/rods out of a 04' GTO ($150) and throw a new set of rings in ($50) and some Katech rod bolts ($200). All new bearings ($300), ARP main studs ($200), head bolts ($50), LS9 headgaskets ($100), HD timing set from Yank ($72). Cam kit from thunder racing or TSP ($600) + LS6 oil pump ($150). Then just get a set of worked 799/243s.
Sell off all the stock 5.3 **** for a couple hundred bucks.
More cubes = more better
#33
#35
#36
FWIW, I was at my machine guys shop today, inquiring about prices. For a bore/hone, tanked, new plugs, install cam, crank bearings(me supplying them) Polishing the crank was quoted about 500.
#37
Btw, I forgot to add to that list a set of LS7 lifters, SDPC sells them for around $120.
#38
Guess what. WHat a worthless machine shop person name is Matt Bishop I called today ask for a quote. He say cant doing bore from 5.3 to 5.7 I told him alot of people who had done with this with him. I dont understand. The business call Bishop Automotive Machine Shop in 5837 Powell Dr, 30126-3117 Mableton, GA That where Bisop machine shop is. I dont know why he say cant. I even explained to him everything. Told him that I might find a ls1 piston and rods off the 2004 pontinc GTO with low mileage... Asked to doing bore wall from 5.3 to 5.7
#40
It impossible. Because I use VIDEOPHONE the lady on the RELAY who translated me. She explained to Matt Bishop. He not even listen whole sentence when I was not finish explain what is going on and what I need to be done with that machine shop.
