4.8 and 5.3 piston
Old Oct 7, 2012 | 10:33 PM
Go5.3tt06's Avatar
Default 4.8 and 5.3 piston
Hey I need help. I think the engine is not 5.3 it's 4.8 when I bought off the craiglist from the guy it say 5.3 off the 2002 Tahoe. I'd be upset if its 4.8 I don't like 4.8. It look piston show + that mean 4.8? Anyone can help me. If it is 4.8 how I able change to 5.3 or something?
Old Oct 7, 2012 | 10:52 PM
Mangled03gmc's Avatar
Baltimore Whore
Pics of piston? 4.8 will have flat tops in it. 5.3 will be dished, unless it is the aluminum block 5.3, then it has flat tops like the 4.8.
Old Oct 7, 2012 | 11:02 PM
Go5.3tt06's Avatar
It look like not full flat top?
Old Oct 7, 2012 | 11:04 PM
Go5.3tt06's Avatar
Look closer
Old Oct 7, 2012 | 11:06 PM
Baltimore Whore
Thats a 5.3 piston
Old Oct 8, 2012 | 08:15 AM
Go5.3tt06's Avatar
Thats a 5.3 piston
You sure it's 5.3? What cam and heads should I get for my 92 s10
Old Oct 8, 2012 | 08:46 AM
TXSZ66AVLANCHE's Avatar
Yes that's a 5.3, its not a flat top....
Old Oct 8, 2012 | 11:15 AM
Baltimore Whore
Yes im sure
Old Oct 8, 2012 | 01:53 PM
DR132's Avatar
for what it's worth, if you ever do end up with a 4.8 and you want to make a 5.3 out of it all you need to do is stroke it...same bore, same block etc.
Old Oct 8, 2012 | 02:05 PM
chevyboy.520's Avatar
Your going turbo, so unless your going to drop some cash on a nice set of heads. Stock heads will work. You can find a set of used PRC heads for right around 1000. Or get a set of 243's those flow well stock
