4.3 Vortec timing question
Old Feb 8, 2009 | 04:15 PM
colekill's Avatar
KickinAssAndTakinNames
Default 4.3 Vortec timing question
The intake manifold gasket blew on my Vortec 4.3. I've replaced the gasket and got it running again, however it is back firing and running rough. What can I do?
Old Feb 8, 2009 | 04:24 PM
stock48's Avatar
9 Second Truck Club
You need to take out #1 sparkplug, and get engine on TDC where the line on the balancer, and timing cover line up. There should be a little marker in the distributor at 8~9 oclock line the rotor up with that and you should be good to go. You probably have it a tooth out of time or a plug wire crossed. Check plug wires 1, &3 they dont go in order. This is info on a 2000 4.3L.
Old Feb 8, 2009 | 04:32 PM
sonoma43's Avatar
Make sure to double check the firing order and make sure the plugs are on the distributor correctly!
Old Feb 8, 2009 | 05:46 PM
A Low Dime's Avatar
13 Second Truck Club
Youre fucked.
No, your prolly not, but I am. Mine does the same but will not start. Throwing code 1351: Coil High Voltage. Mine pretty much has a short in the wiring harness somewhere or the computer is bad.
Old Feb 8, 2009 | 06:40 PM
stock48's Avatar
9 Second Truck Club
My truck wouldn't fire after I changed the Intake gaskets, and somehow by quincidence the spider assembly took a **** while the intake was off. I probably had the distributor in and out 20 times before I figured it out.
Old Feb 8, 2009 | 06:41 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by A Low Dime
Youre fucked.
Will it run if you spray fuel or carb spray down the TB?
Old Feb 8, 2009 | 06:54 PM
A Low Dime's Avatar
How would this help if I have no spark and already running rich with the new injectors?
Old Feb 8, 2009 | 07:20 PM
stock48's Avatar
9 Second Truck Club
Oh didn't know you had no spark.
Old Feb 8, 2009 | 07:28 PM
colekill's Avatar
well went over the plugs again and found it was wrong. so i fixed that, started it up and its still idleing high not as high though, stoped backfireing, but is still really rough.
ferrellrooster
Mar 6, 2025 03:22 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bsn1989
Jul 16, 2015 08:20 AM
4B11T
Jul 13, 2015 03:48 PM
