4.3 piece of crap
Old Feb 14, 2004 | 02:53 PM
loweredon20s's Avatar
Default 4.3 piece of crap
hey i posted before on how it didnt seem liek it was runnning right this guy i kno hooked it up to a code scanner i guess and its throwin out the following codes
p0151
p0143
p0131
p0174
p0171
ANd does anyone know how i can fix this? he said something about it running lean
Old Feb 16, 2004 | 08:06 PM
Default re
i looked everything up and its running way lean sometimes it feels like it hesitating and its def running lean how can i fix this
Old Feb 20, 2004 | 09:56 AM
Beavis5.3's Avatar
First thing is, what year 4.3?
Second, you didn't say what those codes were that you pulled. Can't fix something on one of these until you know why it's running lean. Bad O2 sensor? Injector problems? MAF problems? The list can go on and on.
With hesitation and running lean, it might be something as simple as a fuel filter being clogged or even the screen in the tank being obstructed.
Can you give us what the codes mean?
Old Feb 20, 2004 | 10:14 AM
Texas Terminator's Avatar
11 Second Club
p0151=low o2 voltage sensor 1 bank 2
p0143=low o2 voltage sensor 3 bank 1
p0131=low o2 voltage sensor 1 bank 1
p0174=fuel trim system lean bank 2
p0171=fuel trim system lean
try the obvious. does it idle ok but lacks power under throttle? if so, your fuel filter is probably clogged. how is your fuel pressure after that? pump going bad? clogged fuel sock? is it port fuel or throttle body injected? what year is it?
Old Feb 20, 2004 | 10:56 AM
[QUOTE=Texas Terminator]p0151=low o2 voltage sensor 1 bank 2
yeh its a 98 it idles fine but if u like take off slowly it hesitates but it slam the gas it takes off reelie fast untiol 3 grand then if feels like its not gettin enough gass cuz it has no power
Old Feb 20, 2004 | 02:20 PM
marc_w's Avatar
Fuel filter? Fuel pump?
(my shot in the dark)
Old Feb 20, 2004 | 03:37 PM
check yo cataletic converter, might be plugging up...
Old Feb 20, 2004 | 04:16 PM
11 Second Club
sounds like the fuel filter is clogged. how many miles are on it?
Old Feb 20, 2004 | 06:50 PM
only has 60,000 where would the fuel filter be?
pewter00
11
Oct 20, 2023 05:40 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
slocaddy
Sep 25, 2015 12:42 PM
SLOPONY
11
Sep 24, 2015 02:47 PM
