4.3 to ls1 in a 97 gmc
Old Nov 22, 2006 | 11:01 PM
mcfarlnd's Avatar
Un-Registered User
Default 4.3 to ls1 in a 97 gmc
aproximately how much of a pain would it be to swap a 4.3 to a v8 out of a 97? how much most importantly? also tranny? im not trying to spend more than what the truck is worth.
Old Nov 23, 2006 | 02:43 PM
ridnlow's Avatar
Going to run you a good bit.. Gotta have v8 motor mounts plus the ls1 adapter plates, new fuel pump, throttle cable, either get a harness made or combine the new and old one together.. I believe your tranny should work.. Im doing this on a 94, but it had a v8 in it, so made it a little easier.. Putting the truck back together this weekend to send it to get exhaust and tranny put in.. Good luck on whatever you choose..
Old Nov 23, 2006 | 04:01 PM
thunderwagen's Avatar
check out ls1truck.com there is lots of swap info on there
Old Nov 23, 2006 | 08:30 PM
mcfarlnd's Avatar
Un-Registered User
thanks
Old Nov 23, 2006 | 08:33 PM
mcfarlnd's Avatar
Un-Registered User
would it be easier to use the pre-99 350.
Old Nov 24, 2006 | 12:20 PM
Yes for that all you would need is the donor motor, fuel injectors, motor mounts, and new chip. Your accessories should bolt right up to the 350.You can use your 4.3 tb with the 5.7 injectors.
Old Nov 24, 2006 | 06:14 PM
mcfarlnd's Avatar
Un-Registered User
so i could still use my same computer, for any 96-99 350?
BigKID
Jul 11, 2024 05:28 PM
SLOPONY
11
Sep 24, 2015 02:47 PM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
