Intake system in cold weather
Old Nov 24, 2006 | 07:12 PM
chevz7102's Avatar
Unhappy Intake system in cold weather
As some of you have herd I have put a AEM Brute Force air intake system on my GMC truck. My question is is it ok to run the air intake system in the winter here in Michigan where the temps get down to -10 or more I dont want the engine to run to lean and blow up. I hope the computer will ajust the proper fuel mixture over the stock air intakes systems air flow I will feel better about running the intake in the winter if someone could answer my question thanks.
Old Nov 24, 2006 | 07:18 PM
chrisj6's Avatar
You'll be perfectly fine. Your trucks pcm has a table for open loop before the truck warms up and hits closed loop at 131* coolant temp. The colder the coolant temp, the richer the fuel mixture is.
Old Nov 24, 2006 | 07:27 PM
It will be fine like stated above. The PCM automatically makes it's adjustments for the correct fuel mixture. EFI works wonders!
Jim
Corvette454l88
Sep 1, 2016 01:24 AM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
therock
Jul 25, 2015 09:23 AM
Suburban2500
Jul 14, 2015 02:10 AM
