383 compression questions
Old Jul 28, 2012 | 02:37 PM
greasemykey's Avatar
Default 383 compression questions
so i am about to start the 383 i have been building. i was checking the compression on my engine and im getting 140psi. im thinking with 62cc heads, flat top pistons and .040 cometics i should be higher. any thoughts?
Old Jul 28, 2012 | 03:29 PM
1FastBrick's Avatar
Custm2500's Rude Friend
As long as there all fairly equal you should be fine. Unless you go severe on the compresion ratio your not going to see the cylinder PSI go up much on a compression test.
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
