370 Is Ready
Old May 27, 2007 | 01:26 PM
  #31
2004SSS's Avatar
yeah they are pretty smal bolts so i knew they would be much. it looks like i may get to drive this thing sometime this summer. grip, when is your truck going to run? we should meet up at the track , id like to join the fun with you and brian!
Old May 27, 2007 | 01:48 PM
  #32
wkdivr's Avatar
what are you using for a fuel pump? I'm assuming you ran a new line from the tank, then are using the factory feed line as the return?
Old May 27, 2007 | 02:01 PM
  #33
2004SSS's Avatar
no see the two lines in the pic? the reurn is a - 6 and the feed is a -8 i removed the factory feed line , im using twin intank walbros.
Old May 27, 2007 | 02:12 PM
  #34
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Where did you get the silver barb fitting for the brake booster?
Old May 27, 2007 | 02:22 PM
  #35
wkdivr's Avatar
Ok...I see it now. What did you do with the little electrical harness that plugged into the factory regulator?
Old May 27, 2007 | 04:30 PM
  #36
2004SSS's Avatar
a local shop had the fitting for the booster.
i dont think there was anything electrical going to the factory regulator.
Old May 28, 2007 | 10:37 PM
  #37
2004SSS's Avatar
well i got bored today and started playing aroudn with it. i poured in the evans npg coolant and discovered my passenger side head iddnt have the plug in it. so i lost about 1/4 gallon of coolant. so i get to order some more. i didnt to much since i have the intake elbow off to drill and tap tommorrow at work. i did run the nitrous and fuel lines to the intake. swapped pulleys . fixed the little leak and did the brake booster . here are a couple pics .
Old May 28, 2007 | 11:20 PM
  #38
moregrip's Avatar
what a rush!
looks ****!
are those NPT threads on your fuel rail ends?
Old May 28, 2007 | 11:57 PM
  #39
2004SSS's Avatar
Originally Posted by moregrip
looks ****!
yes they are .
Old May 29, 2007 | 12:41 AM
  #40
How many bungs/holes did you have to drill to connect the booster and sensors?
