370 Is Ready
#31
yeah they are pretty smal bolts so i knew they would be much. it looks like i may get to drive this thing sometime this summer. grip, when is your truck going to run? we should meet up at the track , id like to join the fun with you and brian!
#35
Originally Posted by 2004SSS
no see the two lines in the pic? the reurn is a - 6 and the feed is a -8 i removed the factory feed line , im using twin intank walbros.
Ok...I see it now. What did you do with the little electrical harness that plugged into the factory regulator?
#37
well i got bored today and started playing aroudn with it. i poured in the evans npg coolant and discovered my passenger side head iddnt have the plug in it. so i lost about 1/4 gallon of coolant. so i get to order some more. i didnt to much since i have the intake elbow off to drill and tap tommorrow at work. i did run the nitrous and fuel lines to the intake. swapped pulleys . fixed the little leak and did the brake booster . here are a couple pics .
