370 knock help
Old Aug 13, 2011 | 08:52 PM
SlickSierra's Avatar
i figured trash was getting in the lifters. just drained the break in oil today and put in mobil 1 5w30. the break in oil was 10w30 so it shoulda been fine. ill give it a week and put a new filter on it again to get the crap out
Old Aug 13, 2011 | 09:21 PM
anheuserbusch08's Avatar
sounds normal to me hardened rods and double springs will make it sound like its gonna break apart lol dont worry its just regular valvetrain noise
Old Aug 13, 2011 | 09:33 PM
06murder's Avatar
did you give her a test run on the new oil?
Old Aug 14, 2011 | 12:30 PM
only a startup on the new oil. didnt get a chanve to run it around
Old Aug 14, 2011 | 12:34 PM
06murder's Avatar
does she sound lil bit better now since you changed the oil?
Old Aug 14, 2011 | 12:57 PM
didnt sound any different to me
Old Sep 1, 2011 | 11:12 AM
so after installing the trunions in the rockers it helped a bit but not really. Im thinkin i got the wrong length pushrods. with the block being decked, heads surfaced, gaskets etc. i need to measure for the correct length. right now im running the 7.4's cause that what i was advised before i started the engine build. I was reading alot on ls1tech and seeing different lengths of pushrods with the tq v.2.
Old Sep 2, 2011 | 12:06 AM
Mang213's Avatar
7.35's are for sale all the time. Didnt realize you were decked. What trunions did you get btw? Im looking to get some soon
Old Sep 2, 2011 | 12:32 PM
Yea 7.35 is gonna be close but the pushrod length checker is on the way just to be sure. i didnt realize the ls7 lifter cup sat .050 higher than the stockers. i got the comp retro fit trunion kit, it was only 150 bucks and they were definitely worth it so you dont have to worry about the stocks and are just way more stout.
Old Sep 2, 2011 | 12:42 PM
Atomic's Avatar
I have a gauge for that
There was an extensive discussion about the ls7 lifter height on ls1tech and I think the conclusion was there are 2 different lifters that are called "ls7" lifters, one is 0.050 higher, and the other is the same as the ls1 lifters, the latter of which being the newest design.
You just need to check it with your checker and dont let a post on the internet tell you what length you need.
And break in oil isnt any thinner, it just has more zinc and magnesium in it.
