Which 34" radiator?
Old Mar 1, 2009 | 12:23 AM
CashDudeHomie's Avatar
Default Which 34" radiator?
Yes I did a search.
Can I use any 34" radiator from an automatic transmission truck?
Or does it need to be from a 1500?
If I get a 2500 radiator, will the 1500 trans lines plug right in? And can I just plug up the oil lines and not use them?
Thanks.
Old Mar 1, 2009 | 12:39 AM
thunder550's Avatar
High on diesel fumes
All of the 34" radiators are the same AFAIK.
Old Mar 1, 2009 | 12:43 AM
Thanks. I'm trying to go with a used OEM one, so that's good to know.
Old Mar 1, 2009 | 01:01 AM
thunder550's Avatar
I know that the fan shrouds are different from 1500 to 2500, but I'm almost 100% sure that the radiator itself is the same.
Old Mar 1, 2009 | 07:36 PM
budhayes3's Avatar
PT's Slowest Truck
AFAIK, the only difference is the oil cooler lines, which you can easily plug off
Old Mar 3, 2009 | 04:04 AM
Alright thanks; I just wanted to make sure it was safe to plug up the oil cooler lines in the radiator.
I do still have the oil cooler lines from my 6.0 swap. Has anyone actually used them on a 1500? Or are they only good for trucks that tow a lot of weight?
Old Mar 3, 2009 | 04:27 AM
Parke10's Avatar
if yer asking if a tranny cooler is good or not.. i think an aftermarket tranny cooler should be a must even for a 100% stock truck towing or not.
Old Mar 3, 2009 | 10:34 PM
truckmann's Avatar
I have the engine oil cooler lines on my truck. Not really necessary, but I figured a little extra cooling and oil capacity won't hurt either.
Tigger Welder
Oct 1, 2015 08:41 AM
old motorhead
Sep 29, 2015 08:22 PM
TrickTurbo
Sep 25, 2015 11:22 AM
whitelazer
Sep 22, 2015 09:38 PM
