317 heads?
Old Jul 30, 2005 | 03:34 AM
thunder550's Avatar
High on diesel fumes
Default 317 heads?
For a 6.0 swap with the Radix and good cam....would it be better for me to try and find a motor that comes with the heads or buy them separately? How many 6.0's have the 317 heads? Should I leave them stock or is it worth the money to have some work done on them?
Old Jul 30, 2005 | 08:48 AM
quicksilverado's Avatar
Get an lq4 it has the lower C.R. that will work better with F.I. You will not see as big of an increase with head work and s/c as you would see n.a.
Old Jul 30, 2005 | 09:51 AM
budhayes3's Avatar
PT's Slowest Truck
I think that all of the 01 and up 6.0's come with 317 heads, but I'm not sure. I found a set of clean heads off of an 04 on ebay for $360 shipped, probably gonna have em worked a bit, depending on how much it'll cost.
Old Jul 30, 2005 | 10:51 AM
thunder550's Avatar
OK so if there is a good chance I will find a 6.0 with the 317 heads then I will look sthat way, rather than buying a set separately.
Old Jul 30, 2005 | 11:02 AM
budhayes3's Avatar
PT's Slowest Truck
BTW, but I dig the new sig pic with the Radix
Old Jul 30, 2005 | 11:05 AM
thunder550's Avatar
LOL thanks I spent about 2 hours trying to figure out how to do that in Photoshop
Old Jul 30, 2005 | 11:12 AM
desTRUCKtive's Avatar
motors that are 01 and up have the 317 heads. yeah try to find a motor that 01 and up. Those heads will help you flow especially on the exhuast side.
Old Jul 30, 2005 | 11:17 AM
thunder550's Avatar
Ok thanks I'm sure it would be better price to get a motor that has them already.
BTW....why are you posting when you should be working on getting that motor ready??? You got two weeks
Old Jul 30, 2005 | 11:30 AM
BigTex's Avatar
Only buy a 6L if it has 317 heads. Old ones (99-00) with iron heads have a different crankshaft. They won't be a direct drop in swap.
Old Jul 30, 2005 | 11:36 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, from what I understand, the 99-00's won't bolt up to a 4L60e, you'd have to swap in a 4L80E also.
