3000 stall
Old Sep 21, 2003 | 08:03 PM
Default 3000 stall
I was interested in knowing the effects of engine longevity on 5.3 engine with 3 minute piston slap at start up would be if I add a 3000 stall speed torque converter?
Old Sep 21, 2003 | 08:29 PM
F8L Z71's Avatar
Default Re: 3000 stall
i have yet to see any evidence of any motor losing significant logevity from a stall converter.
It's a good stall. I actually like part throttle now better than when stock.
Old Sep 21, 2003 | 08:33 PM
Does your 5.3 have piston slap at start up.I am concerned that stall might cause to many rpm before warm up and piston slap goes away.
Old Sep 21, 2003 | 08:39 PM
XLR8NSS's Avatar
Adkoonerstrator
I don't think how long your engine will last can be predicted. It could go tomorrow or last 100,000+ more miles.
The only time the stall will cause any more wear on the motor is when you get on it. Those higher rpms than normal will only be for a short time and really shouldn't cause much if any wear. While cruising it'll lock up just like stock and the engine will run just like normal.
I'd actually be more worried about the trans because the trans temps will go up with a higher stall. If you put the stall in go ahead and have a trans cooler put in at the same time.
BTW, welcome to the site.
Old Sep 21, 2003 | 08:40 PM
XLR8NSS's Avatar
Adkoonerstrator
Just let your engine warm up a little longer than normal if that's what your worried about. As long as you're easy on the gas starting rpms should not be excessive.
Old Sep 21, 2003 | 08:45 PM
I've run a Yank 3000 in my daily driver for over a year with no problems.The increase in performance is great with no loss of drivability.
Old Sep 21, 2003 | 08:51 PM
thanks for info,I know just about everyone with a 5.3 has piston slap till it warms up,just wanted to know if condition gets worse after installing torque converter.I have installed hppIII AND 160 STAT,CORSA EXHAUST ORDERED TODAY!
Old Sep 23, 2003 | 11:06 AM
bludool's Avatar
Whitt1,
Do you do any towing with your vehicle? If so, how does the stall effect its ability to tow?
Old Sep 23, 2003 | 12:26 PM
what is the stall on the stock converter?
Old Sep 23, 2003 | 02:00 PM
parish8's Avatar
single digit dreamer
Whitt1,
the yank3000 has full towing rating, 8000+lbs. you can feel it sliping a little in the first 2 gears wich is no big deal at all unless all your towing is in town. once it gets up to speed and hit over drive and lock up it is exactly the same as stock.
here is my problem with one when towing, when you start to pull a hill with a heavy load the first thing the comuter does is unlock the converter. normaly this is only a couple hundred rpm change but with the yank it is more like 1000rpm change, it is just like a full gear kick down. somewhat anoying if it is locking and unlocking regularly. my fix for that was to just shift it into 3rd when towing in a hilly area and that is probably recomended anyways, now it stays locked but at a little higher rpm. once i got the 6.0 and blower in there the thing would almost never unlock even in over drive. moderate load up a hill against the wind at 90mph in overdrive locked up, just lug right up it at 2000rpm or so .
