3" duals or 4" single exhaust?
Old May 30, 2005 | 08:50 PM
454SuperSport's Avatar
Default 3" duals or 4" single exhaust?
getting rid of these shortys in the near future and getting some pacesetter long tubes. i can't decide if i want to go with 3" duals with an X-pipe or go into a single 4". i'm pretty sure i'm gonna use borla xr-1 mufflers either way. some of you FI guys, give me some suggestions.
Old May 30, 2005 | 08:55 PM
NovaTime's Avatar
well, it is all about flow area/flow rate.
4" pipe has a flow area of 12.56 in^2
Dual 3" pipe has a combined flow area of 14.14 in^2
That said, dual 3"
Old May 30, 2005 | 08:58 PM
Mr. Sandog's Avatar
Unless all you need is 10"^2, then both would be overkill....
Old May 30, 2005 | 09:02 PM
NovaTime's Avatar
Supercharger + LTs = need for dual 3"
Old May 30, 2005 | 09:19 PM
Kano's Avatar
2 x 3" is my vote also
either way
mind posting some clips when you get done?
Old May 30, 2005 | 09:23 PM
XLR8NSS's Avatar
Adkoonerstrator
dual 3" has more frictional surface area than a single 4". Single 4" is lighter also(assuming same guage pipe).
I'd like to see some real world test one day about the dual 3" or single 4" arguement though. Anyone have a link to something on that subject?
Found a nice little chart for pipe sizes on Torque Tech's website.
Old May 30, 2005 | 09:52 PM
white1's Avatar
So I guess I really screwed up getting 1 si/so 2.5 magnaflow. Should've went 3"
Old May 30, 2005 | 09:57 PM
Dub Silverado's Avatar
No, you should be fine, most of these other guys are blown.
Old May 30, 2005 | 11:43 PM
white1's Avatar
Thanx. Dub I must say you have some great customer service. Thanks for all the help
Old May 30, 2005 | 11:47 PM
(Ken)-Blown-383 4x4's Avatar
I run dual 3" pipes y-piped into a 4" Magnaflow diesel muffler with a mandrel bent 4" diesel pipe to a 5" tip...best money I ever spent and it sounds like no other truck I have ever heard...very low pitch sound...loves setting off car alarms...go to the moves and I can get 5 or 6 going at one time
http://james.jaguar.net/kctrading/383-5psi-1-2-run.avi
As mentioned above...lighter weight than duals and a single system keeps the exhaust temps a bit higher which helps on the flow as well.
Ken
