3.5" MBRP on a 5.3 ecsb
Old Apr 8, 2006 | 08:24 PM
dave_ix's Avatar
Default 3.5" MBRP on a 5.3 ecsb
Does any one have an3.5" MBRP single exhaust cat back on there 5.3 truck?
Here is a link to there site. http://www.mbrp.com/products.php?S5014304
Please let me know what you think of it.
Old Apr 8, 2006 | 09:53 PM
McKlusky's Avatar
I have not used the MBRP. About 1 year ago I picked up an exhaust off a Duramax (they are an oddball size, between 3.25" & 3.5" diameter) I used the tailpipe (with an angle modification so the exit was more of a 90 degree) and I used the Duramax pipe in front of the muffler. I used a 3.5" single inlet & outlet Dynomax Ultraflo muffler. The pipe in front of the muffler was welded to the merge point of the factory Y-pipe. I did retain the Duramax 4 bolt flange right behind the Y-pipe.
My truck is a regular cab, short bed, with a Magnacharger equipped 5.3. The power is better with the current exhaust than it was before with a Magnaflow single 3" catback, and the summer running temperature dropped about 18 to 20 degrees on a 100 degree day. The sound is medium deep and throaty.
There are alot of like new Duramax exhaust systems just laying around exhaust shop scrap piles due to people buying the truck and immediately changing the exhaust.
Old Apr 8, 2006 | 10:22 PM
quicksilverado's Avatar
Unless you are F.I. or running big cubes it will hurt your bottom end.
Old Apr 9, 2006 | 08:10 PM
dave_ix's Avatar
Thanks guys.
I guess that it will sound loud and have less tq then.
Old Apr 9, 2006 | 09:50 PM
99Silver6.0's Avatar
Too much pipe!!
Old Apr 10, 2006 | 10:12 AM
Full_Pull6.0HD's Avatar
Well the gas 3/4-tons also have that large exhaust. On big difference is that here is no y-pipe on the 2500's. Just dual 3" pipes running parallel into the muffler. Thought this may be an F.Y.I. Although I'm sure it would be difficult to find or even make this stuff fit.
Old Apr 10, 2006 | 06:56 PM
N/A 5.3 doesnt have enough need for that.
Old Apr 10, 2006 | 07:08 PM
I built a 4" cat back with a dmax kit and it sounds and performs awsome. No noticable loss in low end. I think it looks like an awsome kit. I say go for it, LS engines love to breath.
Old Apr 10, 2006 | 09:19 PM
SweetS10V8's Avatar
Dont they all?
Old Apr 10, 2006 | 09:22 PM
5" is better!! **** it! Bully Dog makes a GREAT cat-back for the LS1!!
