243's
Old Jan 16, 2008 | 01:00 PM
  #21
Banned
stock gasket with a 224/224
Old Feb 25, 2008 | 02:30 PM
  #22
HotRodV6's Avatar
SyTy Speed Shop
Originally Posted by joshua022
My 243s were milled .055 and they measured out at 57cc.
with the 57cc chambers, what was your final CR and what thickness head gaskets did you use?
I have some LS2 243 heads, that i want to swap on along with an MTI Stealth cam that is 220/220 .581/.581 on a 115 LSA, and would like to have around 10.5:1 CR and get a tune. And i know a 59cc will give you around 9.8:1 CR.
Old Feb 25, 2008 | 03:05 PM
  #23
silver-mod-o's Avatar
Hunt&Fisherator
mill them .040 and run a .040 cometic gasket... double check your pushrods and you'll be good...
Old Feb 25, 2008 | 03:35 PM
  #24
sbw9056's Avatar
Originally Posted by ZZebes
Use the head gaskets for your block not your heads
5.3 must use a 5.3 gasket
Why do you sat that?
Old Feb 25, 2008 | 03:44 PM
  #25
joshua022's Avatar
I actually sold those and bought some PRC satge 2.5s, that I put on this weekend. they were milled .045 giving me a 57cc chamber and I was told to use 7.35" pushrods, and a .040 5.7 gasket. My CR is 10.53:1-SCD and a 8.22:1 DCR.
I'm trying to fine some used 8.1 injectors or some other injectors so I can get it tuned in. right now its on the stock injectors.
Old Feb 25, 2008 | 04:48 PM
  #26
Hunt&Fisherator
I'm pretty sure he's saying that with consideration of the bore size.
Old Feb 25, 2008 | 04:55 PM
  #27
sbw9056's Avatar
As far as I am aware, there should not be a problem using 5.7 gaskets on a 5.3. There would be a minimal increase in combustion chamber volume though.
zblee
Nov 11, 2015 12:41 AM
tim wellington
Sep 29, 2015 10:17 PM
old motorhead
Sep 29, 2015 08:22 PM
Slammed silverado
Sep 28, 2015 06:14 PM
brandon6.0
Sep 25, 2015 11:58 PM
