226 226 is in
Old Mar 11, 2006 | 08:51 PM
v8
17,16,15,14,13,12,11 Drvr
Default 226 226 is in
Put the cam in and removed the springs to put new valve stem seal on and back together, than took it for a spin, times will tell after the track tomorrow.
Old Mar 11, 2006 | 09:15 PM
Yelo's Avatar
Sweet !!!, let us know how that 226 runs !!
Old Mar 11, 2006 | 09:32 PM
ap2002's Avatar
cool kevin, so I guess it is running good with that tune huh?
I'll see you tomorrow at the track!
what time are you planning on getting there??
Old Mar 11, 2006 | 09:34 PM
v8
right now its hard to say, the tune is good to go from the other cam, it brought my LT fuel trims to 0.0 at idle and -1.6 at cruising wot 0.00 can't beat that. 02's are reading about 875 and 13.0 on the a/f ratio
Old Mar 11, 2006 | 09:35 PM
v8
around 5pm i think or close to it.
Old Mar 11, 2006 | 10:19 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why didnt you change the seals out when you out the springs on like a month ago?
Old Mar 11, 2006 | 10:34 PM
Sport Side's Avatar
I'm anxious to see how it performs.
Old Mar 11, 2006 | 11:15 PM
v8
the air compressor was messing up, so all i had time to do then was get the springs on. No matter there on now.
v8
so am I!
Old Mar 11, 2006 | 11:48 PM
La Riddler's Avatar
good luck Kevin, How different does it feel
with this cam? Do you feel it stronger?
