215/223 lsr
Old Dec 13, 2011 | 09:44 AM
Nflddog1000's Avatar
Default 215/223 lsr
I am looking hard at this cam for my CCSB saw a desktop dyno and made real good #s down low question is they used 799 heads i dont think my 05 has those heads what should I do, gonna have to spend a $ on my heads springs/valves/mill
Old Dec 13, 2011 | 09:52 AM
Cam specs are 215/223 .604/.610 112lsa
Old Dec 13, 2011 | 12:58 PM
SweetS10V8's Avatar
Awesome cam for any street driven Silverado... Ive dynoed with it before and it performs extremely well!!! Youll need a set of beehives, I run the Comp 918s on this cam when I install it.
Better heads is always a good idea(see sic quote) but you dont require them.
Old Dec 13, 2011 | 02:16 PM
Tq was 393 at 2000rpm so great for my heavy truck, if I get close to that I'd be happy. have been hearing bad things about those springs
Old Dec 13, 2011 | 06:15 PM
Beatdown Z's Avatar
Laid Back
You're prob not going to get 393 ft-lbs at 2000 rpm, but that cam is a good choice, especially if you upgrade to a higher stalling torque converter.
Old Dec 13, 2011 | 06:42 PM
SweetS10V8's Avatar
They had a few bad batches a few years ago, and totally redesigned the spring. You hear about one breaking every now an then, but thats because they put out probably 200,000 of those springs a year. THere is a certain percentage of failure in any valve spring, no matter who makes it. You just hear about 918s more, becuase there are WAY more of them out there than anything else.
I run them on my personal vehicle and put them on almost every street engine I install a cam in. The likelyhood of a breakage is very low.
Old Dec 13, 2011 | 06:50 PM
The other cam choice was truck torquer 1 looks good to any opinions (off topic but I cant access this site on my computer only iPhone
Old Dec 14, 2011 | 07:31 AM
The lsa on the lsr Is 112 but if it was 110 or 114 what changes
Old Dec 14, 2011 | 09:00 AM
SweetS10V8's Avatar
110 = More overlap, more lope, slightly harder to tune, more bottom end
114= less overlap, slightly less lope, a little easier to tune, shifts powerband up a little.
Edit: I found my old dyno data on this cam!
Old Dec 14, 2011 | 01:01 PM
I've heard that my stock heads are only good for .550 lift this cam has over .600 and they say works with stock heads ?
