212/218 112lsa Torque?
#21
coming with personal experience, the 212/218 is perfect for what you want it,, and no you dont need a converter or gears, unless you are wanting full out performance... i had that cam on my old z71 and it made a huge difference from idel all the way up... go with it...
#24
#25
I'm with the other guy's on this one; I really think you would like the Comp212/218 low lift on an 112lsa. The LS6 springs will work great with this cam and should prove to very reliable. I also don't believe 4.56' would be too much for your 33" tires, but I do understand worrying about economy somewhat and think 4.30's would make an excellent compromise.
#26
And for the record for anyone else reading, not that I've seen a vacuum issue with that cam on a 112, it can/will happen if you go big enough with your bumpstick.
#27
12499224
LS valve Spring kit
• Beehive style springs
• Used on LS2/LS6 cylinder heads
• 1.800" installed height @ 90 lbs pressure
• Max lift .570"
• 1.250" @ 295 lbs. pressure
• Includes 16 of P/N 12586484
LS valve Spring kit
• Max lift .570"
#28
#29
#30
