212/218 112lsa Torque?
Old Apr 30, 2010 | 04:51 PM
  #21
ap2002's Avatar
coming with personal experience, the 212/218 is perfect for what you want it,, and no you dont need a converter or gears, unless you are wanting full out performance... i had that cam on my old z71 and it made a huge difference from idel all the way up... go with it...
Old Apr 30, 2010 | 04:57 PM
  #22
fastnblu's Avatar
So this cam if I were to run it would be fine w/. the LS6 springs. IIRC, they're rated like .550 or is it .575?
Now, if I can just member who said they'd hook me up?
Old Apr 30, 2010 | 05:00 PM
  #23
03CHEVYBOY's Avatar
im putting this cam on my truck along with LT's i cant wait to get it in
Old Apr 30, 2010 | 05:02 PM
  #24
ap2002's Avatar
yes, i also ran it with yellow LS6 springs... i believe they are rated to .575
Old Apr 30, 2010 | 05:54 PM
  #25
1Bear's Avatar
I'm with the other guy's on this one; I really think you would like the Comp212/218 low lift on an 112lsa. The LS6 springs will work great with this cam and should prove to very reliable. I also don't believe 4.56' would be too much for your 33" tires, but I do understand worrying about economy somewhat and think 4.30's would make an excellent compromise.
Old Apr 30, 2010 | 07:55 PM
  #26
PathfinderJr's Avatar
Originally Posted by bluecajun5.3
i know exactly what he is talking about, i don't need an explanation.
like i said, this ain't old school. brakes will be fine with that lobe separation.
That's cool, don't take it personal, man. Seemed like maybe you were hooked on the intake signal for whatever reason. No worries, man.
And for the record for anyone else reading, not that I've seen a vacuum issue with that cam on a 112, it can/will happen if you go big enough with your bumpstick.
Old Apr 30, 2010 | 07:57 PM
  #27
Preston129's Avatar
According to GMPP catalog:
12499224
LS valve Spring kit
• Beehive style springs
• Used on LS2/LS6 cylinder heads
• 1.800" installed height @ 90 lbs pressure
• Max lift .570"
• 1.250" @ 295 lbs. pressure
• Includes 16 of P/N 12586484
Old Apr 30, 2010 | 11:05 PM
  #28
jiar577's Avatar
Cam I posted link to, LT's, & tune = 60HP?!?
At least it's really close, see this thread:
https://www.performancetrucks.net/fo...d.php?t=435536
Old Apr 30, 2010 | 11:09 PM
  #29
jiar577's Avatar
Originally Posted by faster4whl
Let me resentence my question. What would be the best cam to get for a 4x4 truck with stock torque convertor?
212/218 low lift as mentioned!!
My truck is a 4x4 and the cam is perfect. I work on a farm so I tow often and it works great with the stock converter.
Old Apr 30, 2010 | 11:12 PM
  #30
jiar577's Avatar
Yellow springs are perfect for this cam, that's what I have and I think I paid around $40 shipped for them
