203 t0 2009 cam.
Old Feb 28, 2011 | 11:23 AM
urdone's Avatar
Default 203 t0 2009 cam.
Just a quick question guys im new to this nnbs trucks, they selling me a cam the 220 tsp with push rods adn springs, would it fit a 2009 silverado 5.3? Im thinking yes but want to make sure.
Old Feb 28, 2011 | 11:36 AM
AudioPh1x's Avatar
yeah it should
Old Feb 28, 2011 | 12:26 PM
Robert91RS's Avatar
You will need to get some additional parts but yes.
Old Feb 28, 2011 | 05:26 PM
budhayes3's Avatar
PT's Slowest Truck
2003 is a GENIII with a 3 bolt cam and the cam sensor at the rear of the camshaft, while 2009 is a GENIV with a 1 bolt cam and cam sensor signal off of the cam gear. To do the swap, you will need a new cam gear, bolt, timing cover, and cam sensor. You will also need to extend the wires from your current cam sensor to the front of the engine on the timing cover where the new cam sensor mounts. By the time you are done buying those parts, you could have bought two cams that will swap directly in your truck without modification. (well, I exaggerated a little bit but you get the idea )
Old Feb 28, 2011 | 06:07 PM
urdone's Avatar
Ok i have the the cam gear and the cover, but not the sensor whats the differents i need to mounted on the front with the timing cover???
Old Feb 28, 2011 | 10:28 PM
1slowz71's Avatar
i think your better off by buying a cam for your 09 engine that will just slap in
Old Mar 1, 2011 | 08:01 AM
Robert91RS's Avatar
His cam sensor will work just fine because it gets its signal from the new cam gear and already mounts in the right spot. The only way to make it any simpler on his truck is to buy a VVT cam from TSP.
Old Mar 1, 2011 | 11:16 AM
budhayes3's Avatar
PT's Slowest Truck
OK, he has an 09 and is getting an 03 cam...think I had it backwards...
So the 03 cam will be a 3 bolt cam, and his is a 1 bolt cam, so he will need a 3 bolt gear that has the provision for the front mounted cam sensor (LS2?)...so basically all he needs is the cam gear and bolts
Old Mar 1, 2011 | 11:19 AM
budhayes3's Avatar
PT's Slowest Truck
If your truck is an 09 the sensor will already be in the cover, all you need is the gear with tab for cam sensor signal, and bolts for said gear...
In my original post I was referring to swapping an 09 cam into an 03, had it backwards sorry
Old Mar 1, 2011 | 11:31 AM
skoal bandit's Avatar
i hope you are changing your lifters too! I think your truck has DOD lifters.
