203 t0 2009 cam.
Just a quick question guys im new to this nnbs trucks, they selling me a cam the 220 tsp with push rods adn springs, would it fit a 2009 silverado 5.3? Im thinking yes but want to make sure.
2003 is a GENIII with a 3 bolt cam and the cam sensor at the rear of the camshaft, while 2009 is a GENIV with a 1 bolt cam and cam sensor signal off of the cam gear. To do the swap, you will need a new cam gear, bolt, timing cover, and cam sensor. You will also need to extend the wires from your current cam sensor to the front of the engine on the timing cover where the new cam sensor mounts. By the time you are done buying those parts, you could have bought two cams that will swap directly in your truck without modification. (well, I exaggerated a little bit but you get the idea
)Trending Topics
So the 03 cam will be a 3 bolt cam, and his is a 1 bolt cam, so he will need a 3 bolt gear that has the provision for the front mounted cam sensor (LS2?)...so basically all he needs is the cam gear and bolts
In my original post I was referring to swapping an 09 cam into an 03, had it backwards sorry
