2011 avalanche Magnuson h.p
Old May 8, 2018 | 11:08 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by tatt2oed
I am pretty sure after looking, I removed some wring and tubing from under the truck, that the previous owner had a methanol kit, since it has been removed, could the problem stem from that or in the tune?
The Tune will not cause that issue.
It's likely a loose wire somewhere. Check the fuse block connection, the PCM connection, check the grounds at the back of the block.
Old May 8, 2018 | 12:10 PM
tatt2oed's Avatar
Registered User
I have checked grounds, new battery, have not checked ecm. Its just like someone turns the switch off. I don't lose the radio memory like a power loss, the engine revs like the trans is neutral, it makes that cycle, then its normal
Old May 8, 2018 | 12:39 PM
1FastBrick's Avatar
Could be the ignition switch.
Old Sep 17, 2018 | 10:46 PM
tglandon's Avatar
i have mine supercharged and with factory magnason tune it was as advertised.. 100 hp and 120 lbs. Basically stock engine. So that put me at 350+ rwhp and 400+ rwlb. I got a Westers tune and it has a big seat of the pants feel but i havent been back to have it dyno'd yet. it does pull my 26 ft trailer alot better.
Old Sep 18, 2018 | 08:17 AM
Before you switch to the smaller pulley you should verify what fuel system is in the truck.
Adam Barber
Feb 8, 2018 01:50 PM
applebmw
Jan 9, 2016 01:57 PM
0235SS93
Nov 1, 2013 12:34 PM
bigsapper
Sep 3, 2013 05:40 PM
8UALIVE
45
Apr 14, 2011 11:36 AM
