2011 avalanche Magnuson h.p
It's likely a loose wire somewhere. Check the fuse block connection, the PCM connection, check the grounds at the back of the block.
I have checked grounds, new battery, have not checked ecm. Its just like someone turns the switch off. I don't lose the radio memory like a power loss, the engine revs like the trans is neutral, it makes that cycle, then its normal
i have mine supercharged and with factory magnason tune it was as advertised.. 100 hp and 120 lbs. Basically stock engine. So that put me at 350+ rwhp and 400+ rwlb. I got a Westers tune and it has a big seat of the pants feel but i havent been back to have it dyno'd yet. it does pull my 26 ft trailer alot better.
applebmw
Jan 9, 2016 01:57 PM
bigsapper
Sep 3, 2013 05:40 PM
8UALIVE
45
Apr 14, 2011 11:36 AM
