2005 Silverado 4.8l Injector question
Old Oct 7, 2007 | 08:49 AM
SSnakekiller's Avatar
Default 2005 Silverado 4.8l Injector question
Anyone know what style injectors this vehicle uses? Is it the LS1 style or LS2 for this year? Im pretty sure 2004 uses LS1 style right? I'm not sure if 2005 uses LS2 style yet?
Any links to injectors?
thanks
Old Oct 7, 2007 | 09:47 AM
BlownChevy's Avatar
blownerator
25 Year Member
thanks
same as 04
Old Oct 7, 2007 | 10:52 AM
So the racetronix 42's would be fine? The Lucas brand?
http://www.racetronix.com/621031.html
Old Oct 7, 2007 | 10:56 AM
BlownChevy's Avatar
blownerator
25 Year Member
negative, that is a bosch style connector. I would get the 8.1L Marine GM Delphi Injectors.
Old Oct 7, 2007 | 11:10 AM
nightrunner's Avatar
Mr. Obvious
trucks have a different style connector than the cars
Actually I'm almost positive these will work:
http://www.racetronix.com/17113739.html
Here is a pic of the connector:
But I am not sure about these:
http://www.racetronix.com/17113813.html
Old Oct 7, 2007 | 11:32 AM
BlownChevy's Avatar
blownerator
25 Year Member
If you are looking for a direct drop in, and bolt in the 42 pound 8.1L Marine injectors from GM are your best bet. You will need tuning either way.
The shorties will not be easy, as they are shorter than the stock injectors.
Old Oct 7, 2007 | 03:58 PM
ANy links? I cant find these.
Here is a reply straight from racetronix in response to my question about the specific truck:
These are the only injectors that are a direct fit:
Old Oct 7, 2007 | 04:28 PM
67SS509's Avatar
10 Second Truck Club
That Multec 2 from Racetronics is the GM 8.1 marine injector. If you need an injector that big it's the one you want.
Old Oct 7, 2007 | 04:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
my bad, you are on the right track with those.....I read "shorty" and ASSumed that they were shorter than the stock ones. You are good to go with those.
OHsixLS3
Dec 27, 2016 09:30 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
mzoomora
Jan 3, 2016 07:06 AM
85SS/85GN
Jul 22, 2015 12:48 PM
Moto733
Jul 12, 2015 10:25 PM
