2004 silverado door bell?
Old Aug 31, 2003 | 05:00 PM
2k2ss's Avatar
Default 2004 silverado door bell?
how the hell do you kill this thing it's driving me crazy!!!!!!!!!!!
Old Aug 31, 2003 | 05:06 PM
MacADaYear's Avatar
Default Re: 2004 silverado door bell?
I dont know if its different for 2004 but you can unplug the NBS trucks...
If you cant do that wrap some cotton around it... atleast it wont be as loud...
Old Aug 31, 2003 | 06:03 PM
Hit Man X's Avatar
I took my PCM under my steering column out. That little bozzer/bell is inside there. There are about 4 bolts that hold it in place and some assorted wiring harnesses. Just remove it all and pull that PCM out.
It is a little black thing inside that case that is about as large around as a nickel. Just cover it with tape if you want or be like me and crack the top of the black thing open and remove the element that makes the sound.
Old Aug 31, 2003 | 08:01 PM
GREGGO's Avatar
I wonder how much wiring changed from 2002 to the 03/04's. That may not even be in the same location. Let us know if it is.
Old Aug 31, 2003 | 11:21 PM
Flyer's Avatar
I know in the 2003's the chime goes through the factory radio, which if you are putting in an aftermarket radio and want to keep the chime, you have to buy a $50 wiring harness and mount the factory radio somewhere else, as well as a seperate speaker.
If that's the case .. you can't get rid of it unless you replace the radio. Good luck findnig a wiring harness too!
Old Sep 1, 2003 | 01:10 AM
CashDudeHomie's Avatar
I hate that b%%ch too when I'm trying to listen to the radio and work on one of the cars, I can only leave the passenger door open. I will try to figure out where this speaker is and remove it. If anyone has a pic that would help us.
Old Sep 1, 2003 | 01:37 AM
I opted to keep mine in the 2003, by getting the extra speeker box that plugs inline. I like the fact that it chimes whenever there is a problem like low gas, or I left my blinker on too long, or a dummy light goes off!
Old Sep 1, 2003 | 03:14 AM
Flyer's Avatar
Cash .. that speaker is the front left door speaker. If it's that much of a probelm replace the radio and don't hook up the factory radio.
The additoinal speaker is an optional item with the wiring harness.
hodgee .. where did you mount it? I thought about using the rear left since it isn't being used. I have an amp pushing a componant set in the doors, and I don't use the rear speakers, so I was thinking that I could make it a chime speaker.
I would most definantly leave a plug so I could unhook it when I want to leave the driver's door open though.
Old Sep 1, 2003 | 09:07 AM
If you want to have the drivers door open with the radio on, just take a screwdriver and flick the latch on the door closed, you just have to remember to pull the door handle to release it.
Old Sep 2, 2003 | 11:32 AM
SkagSig40's Avatar
My door chime skips once in a while. It should chime 5 times but sometime it will chime 4 times and after a short delay maybe 3 seconds it will chime a 5th time.
