2003 LQ4 / 2006 LQ9 swap
I've got a 2003 1500hd with a stock, high mile LQ4 (dbw). I have a complete low mile LQ9 in my shop with a TVS1900 installed. I'm looking for my easiest option to complete the swap. Will I be able to use the 03 PCM and harness to run the 06 LQ9 (using hptuners to swap tuning parameters over to the stock 03 PCM) or would it be better to swap in the 06 PCM?
Does the LQ9 have the 24x reluctor wheel? (black crank sensor?)
If yes, then you don't need to do anything except maybe a TB adapter. I'm not sure what the DBW TBs look like compared to what that TVS needs.
Yup, should be really simple.
The 2003 P59 computer will support a 2 bar operating system no problem (literally 99% of them have it available). Input the new injector data, 2 bar map sensor data and start tuning away.
Ok, looks like the 06 has the 58x reluctor wheel and the 03 has the 24x. If I keep the 03 pcm and harness, I can upload the 06 tune and go? I have ordered the return manifold from magnacharger to keep fueling simple.
SimpleManLance
Sep 10, 2010 07:45 PM
Silverado Desperado
Feb 14, 2006 11:28 PM
