2003 5.3 silverado horsepower help
Old Aug 12, 2019 | 11:15 PM
Temps510's Avatar
Registered User
Default 2003 5.3 silverado horsepower help
Hello guys I have a 2003 5.3 silverado that I want to get some more horsepower out of it..it’s completely stock right now but I want to get a small cam not to noticeable in sound but will get power out of it would anyone have any idea on what cam to get also if anyone has any other mods I can do please comment below
Old Aug 13, 2019 | 03:22 AM
Drspencer's Avatar
5 Year Member
How many miles are on the truck? Do you plan on towing? Consider the supporting modifications, as well...
Sonnax 1-2 3-4 billet servos 77911-03K and 77767K
Camshaft (Texas Speed, Elgin, and Summit for the sake of cost) Depending on use of the truck, keep duration at .050 below 220
Valve Springs-Dependent on Cam but LS6 springs if you're below .550 lift or if you're over .550 lift Comp 915, 918, or PAC 1219
Pushrods are recommended but not mandatory unless the measurement is off
Depending on miles and potential slack, be prepared to replace the timing chain however, if it's not worn, I wouldn't touch it since you then have to mess with the oil pump.
Long tube headers and y-pipe.
Higher stall torque converter. I have a trailblazer I-6 converter in my 5500lb avalanche and it's a little bit higher than stock but opens up when I get on it.
Old Aug 13, 2019 | 07:40 AM
Temps510's Avatar
Registered User
The truck has 76,xxx miles and no I don’t plan on towing
Old Aug 14, 2019 | 04:28 AM
Drspencer's Avatar
5 Year Member
https://www.hotrod.com/articles/415h...5-3-ls-engine/
http://www.superchevy.com/how-to/eng...in-your-chevy/
What's your budget? I understand ideally you would want someone to give a recipe. I'm running a comp 54-451-11, long tubes with cats, ported and shaved heads (57cc), and a tune with Sonnax billet servos and a trailblazer I-6 converter. No problems moving 5500lbs, truck has the factory 20s and a 3.73 gear. You have a lighter truck, Put $2500 away and grab:
40k Transmission cooler
Camshaft: Elgin 1840p
Valve Springs: Comp 915, 918, or PAC 1219
Valve stem seals
Valve spring compressor
Higher stall torque converter. I-6 Trailblazer (GM55 at Advance Auto) is $150 and flashes to 2500rpm, great for the street. Circle D is like $600 for something closer to 3000 but it makes a significant impact on acceleration and can take more of a beating.
Finally....you'll need a tune. That'll get you 330hp to the wheels or so and reliable and will last. If that isn't enough, forced induction is next
Old Aug 14, 2019 | 03:07 PM
Alvin@PCMofNC's Avatar
Truck Sponsor
Just depends on how far you want to go down the rabbit hole!
If you wish to keep the rest of the truck stock, our Stage 1 Truck Cam (link) does excellent. We do have larger versions also (stage 2 or stage 3), if you intend to add more modifications, such as headers and/or a stall. Really though just a cold air intake, our stage 1 cam, and a set of electric fans if your truck didn't come with them will make for really nice gains without having to do exhaust or a converter.
Matomic
Feb 11, 2017 03:54 PM
bizle
107
Apr 4, 2014 09:01 PM
smoggist
23
Feb 25, 2012 10:12 PM
parhamcody
Apr 6, 2011 04:13 AM
bgray
37
Jan 1, 2007 05:16 PM
