2000 Silverado - Need exhaust advice
Old Mar 19, 2011 | 09:26 PM
DriftR's Avatar
Question 2000 Silverado - Need exhaust advice
It's my 4.8 regular cab long bed work truck that needs a little tlc. Unfortunately the car gets the big bucks and I need to fix the truck on a budget, but I do want it to last and I need to pass strict inspection.. I need everything from the stock exhaust manifolds back.
I don't need headers but I do need a catted Y and cat back and would like all stainless. Any suggestions?
Old Mar 20, 2011 | 02:54 PM
DriftR's Avatar
Looks like most say to stick with Factory catted Y, but finding one at the junk yard might be difficult... what years directly interchange?
Biggest Problem seems to be having a 4X4 Regular cab with a Long bed... magnaflow doesn't even have a cat-back listed.
So far this is what I've come up with from Summit.
Pypes Stainless Steel Performance Exhaust $453
http://www.summitracing.com/parts/PYE-SGT22V/?rtype=10
Magnaflow Direct Fit catted Y $433 (is this ALL Stainless???)
http://www.summitracing.com/parts/MPE-93419/
Opinions?
Old Mar 22, 2011 | 02:46 PM
DriftR's Avatar
Has anyone used a Pypes Exhaust or have any recommendations???
Old Mar 23, 2011 | 08:00 AM
skyhighsami's Avatar
no title here
I have never heard any Pypes exhaust that I like
Old Mar 23, 2011 | 08:07 AM
budhayes3's Avatar
PT's Slowest Truck
I had some Pypes 3" band clamps and the first one that I went to use broke apart before it completely tightened up, and that's my only experience with them.
I'd trust the Magnaflow y-pipe though, they make a quality product. AFAIK it is completely stainless steel
Too bad you didn't post this a few weeks ago, I had my factory y-pipe with less than 40k on it that I had been trying to find a new home for for over a year. Finally just gave up and cut the cats off of it and mailed them out to one of those places that pays cash for cats
Old Mar 23, 2011 | 09:56 AM
no title here
I might have a stock Y pipe very soon. Depends on if I can find out if F body SW headers will work with my truck.
Old Mar 23, 2011 | 10:43 AM
DriftR's Avatar
Thanks for the responses... I've been workin on it and tryin to keep it as simple as possible. As long as the P0430 code doesn't come back I'm gonna see if I can cut in a cherrybomb or something and dump it in front of the rear tire to pass NY inspection.
The Catco Y pipe I put in is on it's way out after only 3 or 4 years and about 35K miles. I was never happy with it... The driver side is throwing the code and I have heard the insides rattling around from time to time.
If I get it to pass at least I'll have time to do something better in the future so recomendations are appreciated!
Thanks ~Tom
Old Mar 23, 2011 | 12:05 PM
budhayes3's Avatar
PT's Slowest Truck
Thanks ~Tom
If you want to save some dough, empty the kitties out, and have the rear O2's tuned out so you don't throw any codes. I believe that NY has the OBDII plug in and visual inspection like Jersey does, so they won't throw a sniffer in the tail pipe. They just check for codes and check to make sure that the readiness test monitors have run, and if that's all good they slap a sticker in your windshield I've passed in NJ with my StainlessWorks LT's and "catted" :secret2" y-pipe more than once
ARC
57
Feb 21, 2022 10:54 AM
Ketis
Jul 23, 2015 12:37 PM
samg430
Jul 20, 2015 10:12 AM
askkmb
Jul 18, 2015 09:02 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
