2000 LQ9 swap into 1995 gmc questions
Old 07-04-2013, 07:37 AM
drptop70ss's Avatar
Default 2000 LQ4 swap into 1995 gmc questions
Getting set for my first truck engine swap and have a few questions for those who know trucks. I have a 95 GMC K3500 4x4 with the 454 / 4l80e and want to to pull them and put in a 2000 LQ4 6.0 and 4L80e from a 2000 3/4 ton suburban.
First I was hoping to use the transfer case from the 2000 as well, but the burban has push button 4 wheel drive, the 95 has the lever on the floor. Are the transfer cases different or can I put the floor shift lever on the 2000 transfer case? If not will the 95 transfer case bolt up to the 2000 4L80e? I understand the push button system locks the front diff, does that mean the 2000 transfer case is in full time 4 wheel drive all the time?
Old 07-04-2013, 10:19 AM
13 Second Truck Club
LS1FREEK's Avatar
LQ9 didn't start till 2002, you have an LQ4
Old 07-04-2013, 10:24 AM
drptop70ss's Avatar
Ok, forgot the ID, I am used to SB/BB chevys.
Any info on the swap that would help?
Old 07-04-2013, 07:02 PM
gagliano7's Avatar
Go over to ls1truck.com there is a ton of info on ls motors into 88-98 trucks.
OHsixLS3
12-27-2016 09:30 AM
The_W
10-28-2015 09:00 PM
creekrat
08-02-2015 01:27 AM
Ketis
07-23-2015 12:37 PM
Quick Reply: 2000 LQ9 swap into 1995 gmc questions
