2 weeks, .560 lift, stock springs.
Old Jul 19, 2004 | 01:33 PM
Default 2 weeks, .560 lift, stock springs.
Yep, i'm still running my stock springs with the LPE cam. I havent had the extra cash for the 918s yet so i decieded to see how stock springs would hold up. Talking to one of the local chevy dealer mechanics he told me that the stock springs are good for .550 lift. I know i'm over and i do plan to get new springs, but i have been shifting 1-2 at 6500 rpms and 2-3 at 6300 with no hint of valve float of any other problems. I have put a little over 500 miles on it ragging on it hard too.
I dont recommend doing this, cuz i'm sure if i left them in i will break something.
I've had 2 races wit hthe new cam and the results were pretty fun. First was an 02' Trailblazer w/5.3 and the other was a black Lightning. I pulled on the Trailblazer bad. The lightning i didnt pull on till i got up in the rpms and into 2nd. By 75 i had almost 2 truck lengths on him.
More fun stuff to come, unless i get unlucky and blow this motor. Then comes the 6.0 project.
Old Jul 19, 2004 | 03:08 PM
Yelo's Avatar
.560 lift on STOCK springs ???......I was under the impression that the stockers will only do .515 !!!
Hell.....that means that the Comp 212/128 .522/.529 would work on STOCK SPRINGS ????? ...I'm really not sure I'd want to but DAMN, I didn't even know they'd work !!!!
If this is true I could see running stock springs with a non XE-R cam, I would be fairly comfortable using them on a low-lift mind cam
I'm gonna go measure a stocker....I'll get back to you guys in a while on this
Old Jul 19, 2004 | 03:12 PM
zippy's Avatar
he must sit on his ***** instead of the seat in the truck.
Old Jul 19, 2004 | 03:27 PM
Flem's Avatar
yeah there is also guys who have jumped offf the golden gate bridge and lived , the odds are just not in your favor.
Old Jul 19, 2004 | 08:23 PM
FirstGen's Avatar
225 shot? Holy **** batman. If you get un-lucky and blow it? You mean if you get lucky and it survives more than a few bottles...
Old Jul 19, 2004 | 08:27 PM
Sport Side's Avatar
snake eater is a bad ***! stock springs with .560 lift cam.... 225 shot of nitrous....... .050 shaved heads
edit: oops, i thought your sig said somethin about shaved heads before.....
Old Jul 19, 2004 | 08:31 PM
FirstGen's Avatar
must have like 15 degrees of timing pulled and 5 steps colder plugs LOL.
Old Jul 19, 2004 | 08:55 PM
Ryan23silverado's Avatar
I can almost guarantee you are floating those valves. Hit a dyno and look for some nice jagged lines towards 5800rpms and higher Get some good springs and you will probably see a nice gain in horsepower with things working correctly.
Be careful man. If a spring breaks, the probability of a valve dropping isn't to far off. ...But then you could get heads to go with your 6.0L
Old Jul 20, 2004 | 06:17 AM
They are stock heads ported and milled .050. I did some home polishing before i put them back on, but nothin special.
The way it was explained to me is a 2000 LS1 has .500 lift. You can safely go to 1.85 rockers without having to swap springs, whick would be .544 . The trucks springs are suposed to be the same lift specs as the basic LS1.(as per that guy, i dont know for sure)
Old Jul 20, 2004 | 06:37 AM
I've been spraying 225 for about a year. Maybe a little more. Other than burning some plugs getting the A/F set right i havent had any problems YET.
5.3Okasai
Mar 9, 2022 01:07 PM
thunder550
Oct 8, 2015 04:53 PM
lxcoupe
Jul 30, 2015 02:42 PM
Slammed96
Jul 27, 2015 07:22 AM
4B11T
Jul 13, 2015 03:48 PM
