2 Gdamn hours to drop a trans pan. FML :/
Old Jun 30, 2010 | 10:18 PM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
[QUOTE=Mangled03gmc;4490799]
Originally Posted by dlt76028
Your Y pipe looks good John[/QUOTE
Thanks man
Well ima call a friend tom, ask some questions.. It is just to odd, that the bands/clutches would just stop like this imo.. I got it to go in a few times while manually shifting it, when they did shift it went in find, no slipping. The oil looked great, it is a bone stock truck with 72k on it. His wife drives it, when she does she babys the hell out of it..
Your right that is odd... I think your going to have to pull the valve body down. I wonder if the 3-4 check ball is stuck in the plate.
Old Jun 30, 2010 | 10:34 PM
  #22
Mangled03gmc's Avatar
Baltimore Whore
[QUOTE=1FastBrick;4490806]
Well, I think I am capible of doing that. I am not a trans guy, so don't want to step to deep.. I will keep posted.. But yes it is totally weird, how it is acting..
Old Jun 30, 2010 | 10:42 PM
  #23
1FastBrick's Avatar
Do you have a scan tool that can monitor transmission functions? Do you know if the computer is comanding the transmission to shift into 4th
Old Jun 30, 2010 | 10:54 PM
  #24
Baltimore Whore
Thats the prob I don't. I have efi but it is locked to my vin. So if need be I can borrow one of my buddys, to see..
Old Jun 30, 2010 | 11:02 PM
  #25
1FastBrick's Avatar
Well it would be a good Idea to make sure that it is atleast comanding it to shift in to 4th. That way you can rule out the electrical part of things. I am not a transmission Guru but I don't mind getting dirty to fix things. All though it is rare, ocassionally The ECU can be the culprit.
I still feel it is in the Valve body though...
Old Jun 30, 2010 | 11:05 PM
  #26
Baltimore Whore
I hear yah, earlier, I though the same thing, disconnected the batt, for a bit, but still no luck..
Old Jun 30, 2010 | 11:20 PM
  #27
1FastBrick's Avatar
LOL... Disconnecting the battery wont do any thing...
I just had a car in the shop with no Injector pulse on cranking. Intermitently it would start but most of the time it would not. I knew It had to be the ECU on this particular vehical. After looking at the data while it was running then checking the Grounds and power in and out of the ECU. We confirmed it. Tried 2 used ECU's. First one started right up but had transmission signal issues the other was a no start. Put a reman ECU and problem solved.
Old Jun 30, 2010 | 11:25 PM
  #28
Baltimore Whore
LMAO, well it was worth a shot.. What a weird frikn prob.. Where do i get this reman ecu if in fact this seems to be the issue??
Old Jun 30, 2010 | 11:29 PM
  #29
1FastBrick's Avatar
There all over... At the shop, we got it through Pep Boys comercial sales but it was $300
There is a guy on Ebay I used for my buddies truck. It was like $101 Shipped to my door for chevy applications.
Old Jun 30, 2010 | 11:31 PM
  #30
Baltimore Whore
Well I will look into that, but first rule out the prob being in the trans itself..
