18s and how they affect ets
Old Jul 12, 2003 | 06:03 PM
hyper's Avatar
Default Re: 18s and how they affect ets
one stock whee/tire weighs 60lbs?! that doesnt seem right
Old Jul 12, 2003 | 06:12 PM
one03sierra's Avatar
Formerly one92rs
my escalade wheels and 275/60/17 tire combo weighed in at 51 pounds a piece. my twenties weigh64 pounds a piece
Old Jul 12, 2003 | 07:04 PM
creederado's Avatar
Stock GM steel 16X6.5 wheel weighs about 26.5 lbs
With a general 235/75-16 puts it up to about 55 lbs. At least that is what I measured on a regular scale.
my 20's weigh about 75lbs, plus the crappy traction causes me to run about 3-4/10 slower. My 20's without the tires weigh about 34lbs.
Big tires weigh alot to.
Whitt is absolutely right, centerlines are the lightest around.
If your thinking weld, they don't make anything for are trucks(as far as Race rims)
The key to heavy tires is to make more Hp and Trq
Just throw your stockers on and go to the track!
Old Jul 12, 2003 | 08:42 PM
hyper's Avatar
i dont think its so much the weight, as it is the diameter. if u put a low profile tire on the stock 16x7 wouldnt it be faster? ive seen some guys do it. wouldnt this be the same concept ricers do with donuts?
Old Jul 12, 2003 | 09:04 PM
creederado's Avatar
What do you want us to tell you? Wtf do I know? You can bet anything ricers do belong on riceburners. Weight makes a huge differance! I have experimented till I'm blue in the face.
If you want lower et's buy some slicks and throw them on 16's. Either your stock or buy some lightweight ones.
Your already winding the thing out with 4.10's. If you throw smaller tires on there you be closer to shifting into od in the 1/4.
link to caculators.
http://www.randysringandpinion.com/calculators.shtml
Old Jul 14, 2003 | 01:20 PM
tbyrne's Avatar
The 22s on my Suburban weight about 87lbs each. Besides the added weight, the new package might be bigger in diameter so that would take away some of your gear so your ET can change from that also.
Old Jul 14, 2003 | 01:30 PM
GoldenVelvet's Avatar
Many trucks have done very well with large wheel/tire combos, you already have a lightweight setup.
Old Jul 15, 2003 | 10:06 AM
Flem's Avatar
I don't have any et's but the switch from stock to 22's on my s/ced burb was a noticeable drop in acceleration. but I also did give up a little more than 2"s in rolling diameter. 265/70/16 to 305/45/22's
Turk55
Sep 11, 2015 11:52 AM
askkmb
Sep 7, 2015 10:58 PM
hartinclay
Aug 2, 2015 06:44 PM
Ketis
Jul 23, 2015 12:37 PM
fcompean
Jul 15, 2015 09:55 PM
