18s and how they affect ets
Old Jul 12, 2003 | 02:31 PM
hyper's Avatar
Default 18s and how they affect ets
if i took my 18s off, how much would it affect my time? in tenths
Old Jul 12, 2003 | 02:45 PM
Default Re: 18s and how they affect ets
It depends on how much weight you lose on each wheel.If you are removing a heavy 18"wheel/tire comb and putting on a light weight low profile wheel/tire combo you might see a better than1/2sec improvement.If the 18s are light,going back to a 16"steel wheel/tire combo you might see no improvement or even go slower.
Old Jul 12, 2003 | 02:46 PM
one03sierra's Avatar
Formerly one92rs
i went from escalade wheels and 275/60/17 to 20" with 274/45/20 and i lost 3 tenths of a second.
Old Jul 12, 2003 | 02:49 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Sounds about right I guess. I ran solid 16.5 with my 3.73 gears and open diff with the stock wheels and tires.
I got an eaton and 4.10s in, but didn't get to run with the stock wheels and tires because I got the dubs before I got a chance to run at the track
Got the 20s, then ran, so I didnt get to see the difference. I ran a 16.4 with the 20s.
I'm going to run again but with the stockers on and see how I do. Hopefully 16 flats, I dunno.
Old Jul 12, 2003 | 03:09 PM
With 16" wheels,4.10s and a posi you should see mid to low 15s in a 4.8 regular cab,a high 14 wouldn't be surprising.I actually think big wheels hurt a 4.8 more,because of their lack of lowend torque.
Old Jul 12, 2003 | 03:54 PM
lm7's Avatar
lm7
yeah Chingon and those boss motorosports 20s areant even close to being light i always want to weigh them but im afraid to find out what they really do... youll definitly break into 15s by dropping the 20s for some stockers
Old Jul 12, 2003 | 05:15 PM
hyper's Avatar
alright my actual situation is that im running a consistant low 15 on the gtech... 15.2, 15.3, etc. with a best of 15.1. right now im running eagle alloy 18s with 255/55/18 toyos. im thinking that if i go to stockers i will break into 14s. could i?
Old Jul 12, 2003 | 05:51 PM
I doubt you would see much difference unless you went with 20lb Centerlines and 255/50/16 Drag radials.A Yank 3000 with the wheels and tires you have would easily get you into the 14s.
Old Jul 12, 2003 | 05:57 PM
hyper's Avatar
i think the eagles i have are somewhere around 30lbs each. i would think stockers with low profile tires would easily cut off a few tenths. how much do stockers weigh? btw, i want to be in the mid 14s before i get the stall
Old Jul 12, 2003 | 06:01 PM
Close to 30lb,you have a pretty good combo.The stock wheel/tire combo is about 60lb.
