11 pound pulley results
Old Sep 5, 2003 | 12:05 AM
Black Blown 02's Avatar
Default 11 pound pulley results
No knock retard, no belt slip. With Reichard Racing 3.60 pulley and goodyear gatorback belt.
-- Seeing 10 psi at 5800 shift point, up from 8psi with the 4.0 pulley.
-- Maf lb/min at 46.193, up from 40.6 with 4.0 pulley.
-- IAT's go from 82-118 in 1/4 mile at 75 ambient.Went from 82-111 with 4.0 pulley.
-- Timing at 18.5 at 4000 to 12.0 at 5800
-- Yank 3000 stalling at 3725rpm
Going to the track tomorrow. Previous best was 14.8 at 91.
ps.next mod--N2o kit.
Old Sep 5, 2003 | 12:14 AM
tbyrne's Avatar
Default Re: 11 pound pulley results
If everything goes good I'm thinking maybe 14.50s
Boost is an addiction. Once you have a little you want alot more. Your next "fix" is just a pulley change away!
Good luck!
Tom
Old Sep 5, 2003 | 04:03 PM
GMC SKI's Avatar
Give the sucker some more timing try 3-4 More degrees ans see if you get any KR when you add timing
with the Colder weather and good Gas 4 degrees of timing is Very noticable
Give it a try and see what happens
throw a little splash of 100 octane in and have some fun
Old Sep 5, 2003 | 05:58 PM
408 Stepside 01's Avatar
Try to hit 15deg. I know the whipples come with an average of 15deg w/6lb. without an intercooler though. You might be able to get away with it.
Old Sep 5, 2003 | 06:16 PM
Sounds good, I'll try it. Which tables do I modify to add timing? Should I add 4 deg across the board, or just in the upper rpms?
Thanks guys.
Old Sep 5, 2003 | 06:29 PM
GMC SKI's Avatar
across the board will be fine it'll give you some more Zip down low for sure
jim
Old Sep 5, 2003 | 06:33 PM
GMC SKI's Avatar
oh Forgot you will be able to hit 15degrees for sure that is where I'm tuned at
As long as your using 93octane of better you should be there
Now go take it out for a spin with some More timing
What year is your truck ?
the reason i ask is that on my 2002 My Kr sensors suck !! we heard pinging before anything showed up if ever on the tech 2
Old Sep 5, 2003 | 08:14 PM
Only 91 octane avaliable here in Utah. Mines a 2002 also.
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
FormulaZR
Sep 14, 2015 05:23 PM
