1.8 rockers
Old Jun 23, 2010 | 03:47 PM
00buckshot's Avatar
Default 1.8 rockers
cam in my sig, would you guys reccomend running 1.8s with it, heads have NOT been shaved and stock bottom end. Comp said that it would affect the ramp rate and it was up to me
Old Jun 23, 2010 | 06:56 PM
slowec's Avatar
off topic I know , but if you don't have a cut-out and your spraying 200 through a single muffler, you are leaving power on the table. Sometimes ls1tech has better responses to techie questions like this, good luck.
Old Jun 23, 2010 | 07:36 PM
budhayes3's Avatar
PT's Slowest Truck
My opinion, but for the price of 1.8 rockers you can just about get a new cam ground with the extra lift...sure it's a bit more work than just swapping rockers, but you could sell your old cam and make some money back, which would actually make it cheaper than buying rockers. Not sure what springs that you're currently running, but they'll obviously have to accommodate the added lift. Also, how well do your heads flow? If the port job isn't very healthy, the rockers or cam will essentially be a waste. As Comp said, it's your call...
if you do decide on new rockers, be sure to check the swipe pattern on the valve tip...
*EDIT* this is also off topic, but I've been considering that cam (or one that's very similar) for my eventual LQ9...I thought that the specs were 224/230 .581/.588 114...
Old Jun 24, 2010 | 11:27 AM
00buckshot's Avatar
Thats the specs from comp but .581/.592 is the specs on my cam card
Old Jun 24, 2010 | 11:32 AM
PathfinderJr's Avatar
Don't think I'd worry about .003" difference between the two. That's just from variation in the manufactoring. Obviously still within tolerances.
kainzien
Nov 10, 2023 11:37 AM
SS94S10
Jan 3, 2019 01:57 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
