1.8 rocker arms.....
Old Sep 16, 2005 | 08:24 AM
Exclamation 1.8 rocker arms.....
just asking seen at speed inc we can get rocker arms for our trucks i have weak low end after most of my mods (ok maybe its just me ) but would it be a bad idea or good idea... thanks for the help guys
Old Sep 16, 2005 | 08:42 AM
BigBlackAv's Avatar
I think it is good...don't forget valveseats, springs and pushrods while your in there....Crane makes a "quick lift" set that are supposed to be great. I put in the Crane 1.7 quicklift set.
Good Luck,
Damon
Old Sep 16, 2005 | 09:52 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I got a set of Comp pro-magnum 1.75 ratio roller rockers for sale if you are interested I would recommend doing this either with the cranes or mine or whatever it basically increases the lift and duration of your cam and plus adds power since you can set the vlave lash just right for max power and you can feel a SOTP difference for sure.
My rockers are for sale in the classifieds if you are interested.
Old Sep 18, 2005 | 11:25 AM
LS1Tech Sponsor
Harland Sharp has 1.8 roller rockers will be a great addon for your truck add some Z06 or 915 springs when you do it. I have a set on our shop truck they made a big difference.
Nate
Old Sep 18, 2005 | 12:06 PM
thunder550's Avatar
High on diesel fumes
I put some on mine and they really complemented the cam well. I did the cam first and drove it with the stock rockers, then did the rockers a few days later and I could tell a pretty good difference. I say go for it.
kainzien
Nov 10, 2023 11:37 AM
SS94S10
Jan 3, 2019 01:57 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
