1.75 INCH 304 SS HEADERS W/CATS NOW IN STOCK...
LS1TECH Sponsor
We plan on having a 6.0 header back system made.
Installed the FLP this weekend. Nice looking kit with all the parts you need. Overall easy install but a few roadblocks to be discussed below.
1) Clearance problems on the passenger side frame rails near header collector. Had to cut the heat shield and still too close for comfort. On my drive to work this morining, had some rubbing under certain conditions so I will look at this area first. May also be steering column bolt.
2) Collector flange to cat flange connection is a real tuff one. Hard to get to bolts on top of cats and install O2 sensor at same time (you'll see when you get there). Maybe I just don't know the right trick.
3) Kit comes with new spark plug wire for #4 & #5 coils. I found my current magnacore wire a better fit. Need to p/u a 2-wire connector to hold #4 & #5 wire together and away from header tube.
Banned
what if you have the msd wires or taylor wires, will putting fbody wires on two of the primaries hurt anything? 6 of 1 kind of wire and 2 of a different doesn't seem like it would be that great of an idea to me.
Adkoonerstrator
Matt - You should be able to put Fbody wires on all the cylinders if you're worried about it. I'll check tomorrow and see if there would be any problem doing that. Then you could sell your truck wires to someone else.
zblee
63
Jun 10, 2023 01:25 PM
lxcoupe
Jul 30, 2015 02:42 PM
carid
Jul 24, 2015 05:00 AM
Suburban2500
Jul 13, 2015 09:57 AM
