1 7/8 headers overkill for 5.3??
Old Feb 17, 2012 | 10:50 PM
david0982's Avatar
Default 1 7/8 headers overkill for 5.3??
I am wanting to buy some headers for my stock 5.3 and was wondering if 1 7/8 headers would be too much? Future plans are TSP 220 came and stall.
Old Feb 17, 2012 | 11:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
1 3/4" is more than enough.
Old Feb 18, 2012 | 12:09 AM
Jablowme's Avatar
Banned
go to big a tube and your bottom end torque will suffer alot
Old Feb 18, 2012 | 12:51 AM
pewterliftedz's Avatar
unless your running a big converter where you don't care about low end, I would go 1 3/4" with 3" collectors.
Old Feb 18, 2012 | 07:30 PM
silver-mod-o's Avatar
Hunt&Fisherator
Depends on your goals, I've seen some 5.3 setups gain big from 1 7/8 headers... depends on what your going for. Everything is a compromise and with a 220 cam, I'd stick to the smaller primaries.
Old Feb 19, 2012 | 01:27 PM
SamuelsonMotorsports's Avatar
I always try and use the largest primary I can get depending on what im doing (which is usually turning over 7,000rpm) but in your case, you honestly don't need a 1 7/8 header.
The general concensus is "within 10% of the exhaust valve size" but this is just a general rule for the 90% crowd under 500hp. When you start turning alot of rpm and don't care about anything under 4,000- then you start jumping up the primary size considerably.
Now- I say you don't need a 1 7/8 header. Truly, you don't. Now- how much will it hurt going from a 1 3/4 to a 1 7/8? usually 6-10hp at PEAK. Average torque will remain within 3-6 along the curve and average hp will only differ 2-4 over the entire curve. If you feel that you will eventually increase the cubic inches, then go ahead and get the larger headers and live with the slight loss till then. If not, stick with the smaller primaries.
Old Feb 19, 2012 | 02:22 PM
Mangled03gmc's Avatar
Baltimore Whore
All of thee above
Old Feb 20, 2012 | 01:31 PM
david0982's Avatar
Thanks for the input. I will be going with 1 3/4 since I plan I don't on doing anything else besides the cam and stall for now.
Old Feb 20, 2012 | 02:03 PM
TXsilverado's Avatar
if you plan to do a motor swap to a LS1 or larger in the future go ahead and get the 1 7/8. if not stick with 1.75
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
slowlsx
Aug 10, 2015 05:33 PM
Matt331
Jul 26, 2015 09:40 PM
bk_cauley
Jul 19, 2015 09:56 PM
