09 Silverado 5.3 to 6.0 ls2 swap
Old Sep 29, 2016 | 07:55 AM
biggjim313's Avatar
Default 09 Silverado 5.3 to 6.0 ls2 swap
Been lookin around the forums for some info any would be greatly appreciated.
Just picked up a 1 owner very clean 09 silverado z71 4x4 5.3 flex fuel with 177k on it for a dirt cheap price. Not sure of the trans in it yet.
Has misfires on #5 and #7 cylinders.. Dealer says needs new long block.
So I got another great deal on a low mileage complete drive train from an 08 awd ss trailblazer 6.0 ls2.
Looking to find some info on a good cam to add some power but still be tow friendly. I have already ordered a CAI and some longtubes.
Just looking around for any input you guys might have.. Any recommendations or anything thanks.
Old Oct 1, 2016 | 06:47 PM
turboal1's Avatar
Default swap
Will surely need a tune.
Old Oct 1, 2016 | 06:59 PM
Wolftrk99's Avatar
First off why dealer saying it needs a new block??? Which 5.3 is it cast block or aluminum? Secondly, the ls2 is going to be more torque and hp in stock form than the 5.3 to begin with get a cam specd for it and you should be good, but a torque converter will probably be in order...As stated will need to be tuned, what trans does the silverado have if the prndl display reads prnd321 its a 4l60/70 if its prndm or prndm1 its a 6l80 or in some instances 6l90... Rpo codes in glovebox will also tell you that... m30 is 4l60, myc is 6l80, and myd is 6l90!
Old Oct 2, 2016 | 10:55 AM
biggjim313's Avatar
I bought the truck from my company and they said that's what the dealer told them. I have only tried new coils on those cylinders. Just still sputters.
Crazy cause the truck runs rough at idle and smokes but when you hammer down on it, it rips the tires loose and runs great at high speeds.
Also it's the iron block with the 4l60 trans. Has the M30 code.
Old Oct 2, 2016 | 10:57 AM
biggjim313's Avatar
Any good shops to go through for a cam and torque converter?
Old Oct 2, 2016 | 11:12 AM
Wolftrk99's Avatar
Where are you?
Old Oct 2, 2016 | 11:13 AM
biggjim313's Avatar
Where are you?
I'm in Detroit Mi
Old Oct 2, 2016 | 02:08 PM
Wolftrk99's Avatar
Cant help ya there... Lol!!
Old Oct 13, 2016 | 11:09 AM
turboal1's Avatar
Default check out
comp test or leak down test ?
sounds like elect prob.
Old Oct 13, 2016 | 11:12 AM
biggjim313's Avatar
Believe the dealer did a compression test
benmurry
Jan 15, 2017 03:42 AM
dil
Jul 24, 2016 08:48 PM
XL7
Jul 22, 2016 01:34 PM
Cha_Feel_
11
Jul 20, 2016 04:40 AM
urdone
Jul 9, 2016 10:34 PM
