04' Sierra VHO
#22
Oh yeah, I really like the B&B cat-back I'm running. If you've got an extended cab LQ9 - this thing should bolt up. I got the dual rear exit - there is also a dual side exit if you're into that.
It's on the quiet side, but it constantly sounds p!ssed off - especially with the windows up. I guess that means there is a bit of interior resonance. It can get loud outside when you're on it, but not quite as loud as a Corsa or any other completely straight through system.
I also found a gain of lowend torque. Something not to common with dual systems.
#23
Originally Posted by 6.0 badd ***
superchip/single flowmaster/throttle body spacer/asp pulley,
my 60ft with 20's 2.14/ 2.17 my 1/4 mile 14.0/14.1
my 60ft with nitto 245-50-16 are 1.9/ 2.0 my 1/8 mile 8.7/ 8.8
my 1/4 mile 13.7/ 13.8
i see everyone live's in texas come to the track and prove me wrong
#24
Originally Posted by leochevy2001
What color is your truck so that the next time I am out there I can look for you. I do not frequent the track as much as you do though.
james
#25
Originally Posted by marc_w
Are VHO's two wheel drive?
I think the fastest stock SS (stock except for spinning rims) was a lightly disputed 14.9X.
#26
V/HO is a faster truck then the ss because it's not all wheel drive. extra weight for no reason and doesn't need all wheel drive. 3:73 gears over the ss 4:10
Can it be had in half ton, regular cab? What is the horsepower rating on the 6.0? Thanks
#29
man, it's like you have to hold their hand. it's simply a plain 2wd extended cab (NO REGULAR CAB'S) truck with the LQ9 (345hp 6.0) and factory GM Accessories 20's on it. looks like every other extended cab 2wd except with the factory 20's. not much else is different other than the K-chassis they used for the frame instead of a C-chassis.
