'04 PCM/OS in '06 Truck
Anyone done this? All I'm wanting to do is gain the ability to do some RTT with HPTuners. I haven't gotten much feedback yet over on their forum so I figured that I would post it here as well.
I think my options are this:
1)Buy '04 PCM, use a tech2 to flash my VIN to it, and then install PCM in truck. It should work since it will have the same architecture and wiring as my current PCM
2)Flash a '04 OS onto a '06 PCM that has my VIN programmed into it. Of course I'll be doing this with a spare PCM. If I can get the '04 OS to work, then I should be able to "upgrade" to the RTT OS.
Just looking for input on this matter. Either option seems equally involved and should cost the same in the end.
Thanks in advance,
Jake
ps: sorry if this is "technically" in the wrong forum, since it's hardware related I thought it would go here, feel free to move it if it need be
Thanks in advance,
Jake
well on my 2003 i tried to flash it with a stock 05 cal file, using tunercat OBD2 tuner, and was unable to do to the 05 OS being twice the size, but i dont see why it wouldnt work the other way, but have never tried it.
Jake,
intersted in the same thing.
Hoping to use a 2005 L33 file though.
I think RTT is available on an 05 os.
I already have a spare 06 PCM licensed.
let me know what you find out.
As far as I know, currently RTT isn't supported on the '05-'07 PCM's, at least the truck PCM's. BTW, do you have that bog off the line feeling from the throttle not snapping open? I've got it on mine, it takes about 1-1.5 seconds to go 100% from a slam.
Do you have your >>>
ETC TPS% Max: This is the maximum allowed ETC throttle percent based on the current percentage of torque being delivered. The PCM uses this to limit the ETC opening rate to maintain traction.
Maxxed out 100% across the entire table?
I will look into the 04 os.
what have you decided you want to do to get this to work.
It might be simple. might not.
You just never know what you can't see
No lag at all with mine.
As for getting it all to work, you use a '04 pcm with '04 TAC module and '04 gas pedal. It all works, there's a well known person on the board that's done it
. It fixes that throttle delay as well, it snaps open instantly. If somehow we could reprogram the '06 TAC module to have a faster ramp rate that would be quite nice so I wouldn't have to buy all this extra junk, but hey I get RTT at the same time.Jake
