01 tahoe engine removal
Old Sep 26, 2005 | 10:09 AM
weranc55's Avatar
Default 01 tahoe engine removal
I'm pulling the engine on my tahoe and replacing it with a 5.3 I got from a yard. Question should I disconnect the ac lines or should I take of the compressor and put it to the side and put it on the new motor. Same thing for the power steering. Anyone who has pulled a motor on one I could use some advise.
Thanks
Chuck
Old Sep 26, 2005 | 11:18 AM
Zick's Avatar
When I pulled mine, I left everything connected and pulled them to the sides. The power steering assembly was a PITA to move all together.
Old Sep 26, 2005 | 11:33 AM
weranc55's Avatar
Did you pull the pulley of on the pump to get to the three bolts? It does like a pain but I dont know if I disconnect the lines if I would have to blead the steering box? Or is it like a older car where you hook it up and go.
Thanks
Old Sep 26, 2005 | 12:35 PM
Zick's Avatar
Thanks
Nope, left the pulley attached to the pump. I also left the pump attached to the bracket and moved the whole thing aside as one piece.
Old Sep 26, 2005 | 12:45 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Remove the alternator, then remove the pump brackets from the engine (don't try to remove the pump from the brackets). Then suspend the pump/bracket assembly with a piece of rope tied to the battery or something similar on the driver's side. Do the same with the AC compressor. This way you don't have to open-up the lines on either system.
It is very important to suspend these units and not put a strain on the hoses, fittings, etc.
Steve
Old Sep 26, 2005 | 12:47 PM
weranc55's Avatar
Thats my project for the night. I just hope I can get to the trans bolts without removing the intake.
Thanks
Old Sep 26, 2005 | 08:46 PM
weranc55's Avatar
Will I need to take the intake off to get the motor out, Any suggestions on how to get to the bolts for the trans?
Thanks
Chuck
Bumpers
Aug 4, 2024 09:44 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
thunder550
Oct 8, 2015 04:53 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Chiphead
Jul 13, 2015 10:16 PM
